alexose
Alex
Jacksonville, Oregon
2014 C-Max, 1999 F150
If you're like me, you'll agree that a stock F150 Lightning has too way too many audible warnings. This thread catalogs the different methods I've used to turn them off, sorted by overall annoyingness. Hopefully it's useful to someone!
Note that many of these noises are federally mandated, and/or genuinely important for safety. Please use good judgement when modifying your vehicle.
Things I've done:
  • Disable frunk beep. This requires unplugging the frunk speaker. www.youtube.com/watch?v=UdWVnZ5vNgM
  • Disable backup beeper. This also disables the low-speed pedestrian noise, so please be careful with this one. These noises are federally mandated, and you will be ridin' dirty without them. You'll need to install the megaohm speaker delete kit: https://www.megaohmmotorsports.com/product/ford-psbk-ece
  • Disable key-in chime. FORSCAN Code IPC 720-02-01 xx*x xxxx xx-- (subtract 8 from current value (if E change to 6))
  • Disable triple chime on vehicle startup. FORSCAN Code IPC 720-01-02 xxxx x2xx
  • Disable door ajar chime. FORSCAN Code IPC 720-01-02 xx0x xxxx
  • Disable seatbelt chimes. This can be done via a series of button presses and seatbelt clicks. Again, please do not ride dirty. See here: www.youtube.com/watch?v=QcMErUaI3Cg
  • Disable "check rear seats" warning. This can be done via the touchscreen: Settings > Vehicle > Rear Occupant Alert
  • BONUS: IPC quick boot. This disables the annoying (albeit inaudible) Ford advertisement that takes over your screen when the vehicle boots. IPC 720-07-01 xxxx xxxx 2xxx
Things I haven't done, but are theoretically possible:
  • Disable double honk if you get out of the truck while it's running and bring your key with you. Mine actually never did this so I didn't bother with it. FORSCAN Code BCM 726-41-02 xxx0 xxxx xxxx
  • Disable parking sensors. This can be done via the touchscreen, although it is a useful tool depending on where you park. One of the few dings that I left on.
  • Disable power liftgate chime. I don't have a power liftgate, so I skipped it.
Things I still haven't figured out how to do:
  • Disable "Rear sensor blocked" chime (yes, I know when my liftgate is down, Ford!).
  • Disable "No key detected" chime
  • Disable chime on lane keeping cancellation.
  • Disable "transmission is not in park" chime when you open the door without having shifted into park.
  • Disable animation on power down.
I'll update this post as I find solutions to the above noises, or if I discover other chimes that need to be silenced. Again, I hope this is useful to someone-- None of this is new information, but maybe I've saved you some time by not having to search for it.
VAF84
Central Texas
2024 Sierra EV Denali
Consultant
I call my Lightning, Ma Lightning, because I've never been more nagged at by a vehicle in my entire life; and I've had all types.
I'd pay top dollar to get adaptive cruise off my tail about "keep hands on wheel". BTW my hand is on the wheel; just that Ford wants you to shake your wheel every 15 seconds. Almost not worth using it on non-blue cruise supported highway's.
Gaunle
Sanjeev
Frisco, TX
2023 F150 Lightning Lariat ER
Things I've done:
Thanks for the detailed instructions. How did you get around the error message that pops up every time you start the truck once you have your backup beeper disabled using the Megaohm resistor?
alexose
alexose
Alex
I haven't noticed an error with the Megaohm kit. Curious, what is the specific error you're getting?
Gaunle
Sanjeev
Frisco, TX
This is the popup I get on every startups post installation of the Megaohm kit for backup beeper.
Ford F-150 Lightning Disabling F-150 Lightning's Beeps, Dings, Chimes, Honks, Bings, Bongs, and Dongs IMG_20240128_135949
Disable seatbelt chimes. can be done via Forscan, as well...
Disable Auto Doorlocking. can be done via Forscan.
Disable frunk beep. I removed my speaker module easily since I had to remove the front valance and front bumper cover to rewire while adding my new LANE CENTERING radar module and harness...
alexose
alexose
Alex
The point of the megaohm kit is specifically to avoid this error, methinks. I'd definitely contact them and ask for a replacement.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
This is probably corrosion in the connector or the plug has slipped out a bit. A Ford Injector will fit in the connector and solve this issue way cheaper.
The Weatherman
Dean
South Central KY
Leaving with the key while the vehicle is running (Double Horn Honk) can also be deadened via the center screen in Vehicle Settings.
rio
CT
2016 Chevy Volt, 2023 F150 Lightning Pro
Great info - thanks! There's definitely a few of those that I want to get rid of.
Which one is the "key-in" chime?
I've been back and forth about the backup beeper. It use to make me very self-conscious at first but now I don't even notice it - and I think it's a good idea to warn pedestrians that a 6,000 pound thing is coming their way. However, I wish I could disable it in certain scenarios (like pulling into a campsite).
Danface
Dan
Central Mass
2023 Lightning XLT
Could be worse: https://www.webcommand.net/index.php/2017/07/26/talking-cars-80s/
Always remember: "A door is ajar"
alexose
alexose
Alex
The "key-in" chime is the triple-chime ("doo doo doo") that you hear when then doors are closed and you press the start button.
Yeah, I hear you on the backup beeper. It was a no-brainer for me due to where I park (basically right next to my neighbor's bedroom window), but I can imagine people opting to leave it on as well. It'll probably become more commonplace over the years as more and more vehicles have this "feature".
