hotrodmex
Ca
22 Lariat 500.5a
I have successfully added the Tremor Style Camera (full screen front view at speed with tire locators) as shown in the following in full screen:
I'm assuming the tire marks also move with the steering wheel? Just checking since haven't seen a pic with them turned, or that specifically being mentioned.
JIMFOUNTAIN
2021 F150 SCREW PB 6.5' 701A
yes the tire marks move when you turn the wheel. And in reverse you get the usual backup markings.
FordConvert
Craig
Utah
2021 F-150 Lariat PB 502A
Builder
Not sure if this has already been discussed, but had some thoughts regarding FORScan changes and OTA updates.
Some Job 1's who manually updated using FDRS from failed OTA to BC ran into problems if they didn't revert FORScan changes in key modules. For those of us who made it to BC and reapplied FORScan changes, what is the risk that future OTA's will cause issues?
Given this I decided to turn off automatic OTA's so I can check what modules have updates and apply them manually after reverting applicable FORScan mods. Call me a control freak but I'd rather control my updates/software TSB's in FDRS than rely on inept service techs or possible software purgatory of my own making ala FORScan. (Seriously took me 20 minutes to do TSB 22-2117 when a tech had failed at it for two days)
I know not everyone wants to invest time/money into a Mongoose or FDRS licenses but for me it's worth it in this brave new OTA world. Also would be nice to avoid the shop if it's just a software issue.
Maybe I'm off. Feel free to shoot this idea full of holes.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
I have a 2021 Platinum. Up to date. Bluecruise working. Hitch, Bed and rear cameras now selectable at speed. I have successfully added the Tremor Style Camera (full screen front view at speed with tire locators) as shown in the following in full screen:
This camera comes on in the following MODES: Rock Crawl, Mud/Ruts, and Deep Snow/Sand. Setting IPMA 706-02-02 xxxx xx03 xx-- turns on this Tremor offroad camera feature set.
This change has been tested on updated 2021 Job 1 (pre 7/5/2021 builds) Platinums and King Ranches. With and without factory FX4. But it is believed that 2021 Job 2s and 2022s will work as well.... if you already have rear, hitch and bed cameras at speed.
Usual warnings apply.... Your mileage may vary. Always backup first!
Credits: @Livnitup , @Jesse-Infotainment and many other F150 Gen 4 pioneers. Without you guys this kind of stuff WOULD NOT BE POSSIBLE! Thanks.
It worked with me.
But is there away to make 2H works with any mode above?
I have Lariat 502a 2021 Job 2.
jordandev
Jordan
2021 F150 XLT 302A (on order...)
sorry for the full n00b question here because I'm obviously missing something...
downloading my AsBuilt data from the widget (reloaded) or even directly from motorcraft shows me old values. I made the changes in forscan over a week ago now.
Why are they not getting uploaded?
jasonator
Jason
Tampa
2022 F150 Lightning
Has anyone figured out how to get rid of Siruius or AM settings like the ICE 150's? Would the same code work?
Shady
2021 F150xlt
that one is ez on the Pro ver. It only has fm and bluetooth buttons :)
SNBI18
NJ
24 Lariat
Curious if anyone has eliminated the touch screen from disabling options because the truck is in motion? Lariat
Also what about the warning you get if you scroll through to many songs on Spotify for example in Android auto/car play, it pauses you from scrolling for a few seconds
Lastly has anyone been able to shut off the headlight drls so during the day you just have the light bar in the front?
Well, you have stumbled upon the original ICE thread that is over two years old now. ;)
Everything we know about the Lightning can be found in this thread:
https://www.f150lightningforum.com/forum/threads/f150-lightning-forscan-thread.11406/
I'm not aware of FORScan changes for those items so you might search through that thread for keywords like DRL, etc.
SNBI18
NJ
24 Lariat
rugedraw
Javier
Miami
Auto Sales
To enable cameras in motion, I know that one from memory:
706-02-02
xxxF xxxx xx--
Not sure about the other two.
Riverant
MA
2023 F150 Lightning Lariat ER
This spreadsheet is fantastic. I've made use of several of the common adjustments as well as the 'dings, bongs, and chimes' thread. One other that worked well is the heated steering wheel adjustment as mine previously felt lukewarm. I changed mine from a B to a E (F was too hot). This info is in another thread I found via Google but in case it's helpful other others: https://www.f150lightningforum.com/forum/threads/heated-steering-wheel-weak.17084/post-344719
SCCM 724-06-01 *xxx xxxx
0 =HSWLTSP 24°C8 =HSWLTSP 32°C
1 =HSWLTSP 25°C9 =HSWLTSP 33°C
2 =HSWLTSP 26°CA =HSWLTSP 34°C
3 =HSWLTSP 27°CB =HSWLTSP 35°C
4 =HSWLTSP 28°CC =HSWLTSP 36°C
5 =HSWLTSP 29°CD =HSWLTSP 37°C
6 =HSWLTSP 30°CE =HSWLTSP 38°C
7 =HSWLTSP 31°CF =HSWLTSP 39°C
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
If I am reading the spreadsheet correctly, in order to enable the lightning f150 splash screen I modify APIM 7DO-03-01 xxxx 1Fxx xx-- but how do I disable the splash screen?
