Caneman88
Ron
San Antonio TX
2021 Powerboost F150 Platinum ,2009 370Z
Pella Windows and Doors
Does anyone know if there is a way to get a better resolution on BedCam since updated to 2.5.1.
got cameras without ForScan but the res is not as good as before with Forscan.
still don't have BlueCruise but seems close.
also lost this view. this pic is before using Forscan
I was waiting for BC to kick in before using Forscan to mess with cams again.
thanks in advance
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? IMG_1150.JPG
jasonator
Jason
Tampa
2022 F150 Lightning
Has anyone figured out how to get rid of Siruius or AM settings like the ICE 150's? Would the same code work?
Shady
2021 F150xlt
that one is ez on the Pro ver. It only has fm and bluetooth buttons :)
SNBI18
NJ
24 Lariat
Curious if anyone has eliminated the touch screen from disabling options because the truck is in motion? Lariat
Also what about the warning you get if you scroll through to many songs on Spotify for example in Android auto/car play, it pauses you from scrolling for a few seconds
Lastly has anyone been able to shut off the headlight drls so during the day you just have the light bar in the front?
Well, you have stumbled upon the original ICE thread that is over two years old now. ;)
Everything we know about the Lightning can be found in this thread:
https://www.f150lightningforum.com/forum/threads/f150-lightning-forscan-thread.11406/
I'm not aware of FORScan changes for those items so you might search through that thread for keywords like DRL, etc.
SNBI18
NJ
24 Lariat
rugedraw
Javier
Miami
Auto Sales
To enable cameras in motion, I know that one from memory:
706-02-02
xxxF xxxx xx--
Not sure about the other two.
Riverant
MA
2023 F150 Lightning Lariat ER
This spreadsheet is fantastic. I've made use of several of the common adjustments as well as the 'dings, bongs, and chimes' thread. One other that worked well is the heated steering wheel adjustment as mine previously felt lukewarm. I changed mine from a B to a E (F was too hot). This info is in another thread I found via Google but in case it's helpful other others: https://www.f150lightningforum.com/forum/threads/heated-steering-wheel-weak.17084/post-344719
SCCM 724-06-01 *xxx xxxx
0 =HSWLTSP 24°C8 =HSWLTSP 32°C
1 =HSWLTSP 25°C9 =HSWLTSP 33°C
2 =HSWLTSP 26°CA =HSWLTSP 34°C
3 =HSWLTSP 27°CB =HSWLTSP 35°C
4 =HSWLTSP 28°CC =HSWLTSP 36°C
5 =HSWLTSP 29°CD =HSWLTSP 37°C
6 =HSWLTSP 30°CE =HSWLTSP 38°C
7 =HSWLTSP 31°CF =HSWLTSP 39°C
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
If I am reading the spreadsheet correctly, in order to enable the lightning f150 splash screen I modify APIM 7DO-03-01 xxxx 1Fxx xx-- but how do I disable the splash screen?
