Factory Wheels with Aftermarket Tire Thread
zCyko
Lane
Hammond La
2021 f150 XLT
Hey Guys, just got done swapping off the 295/70’s for the 35x12.50r18 Ridge Grappler. I am happy to report ZERO rubbing with a RC 2” level with rear block/shock kit.
Could you post some up close pics of your clearance with the wheel turned
rathbunr5
rathbunr5
Bobby
Connecticut
2022 Ford F-150 Lariat Sport (Space White)
Sales Manager at Torrington Ford
Certainly, I will take some in the morning tomorrow.
jcarrico
NYC
2021 502a (on order)
I am using the Rough Country .25" spacers just to give it the slightest poke. Plus the .25" gives you clearance around the control arm. But 100% rub FREE!
Do the stock lugs/studs still have plenty of thread with those spacers? I've been eyeballing them myself.
rathbunr5
rathbunr5
Bobby
Connecticut
Yes definitely do. No problems there at all. I’ve been running the spacers since the day I bought the truck which was back in may and I haven’t had any issues with loosening lug nuts or anything like that
CaptainAmericaRob
Ed
2021 F-150 Lariat FX4 PB
Machine Designer - Ford Motor Co.
Got the raptor take offs installed yesterday, I will take better pictures later today. 315/70/17 BF Goodrich K02 tires on 21 raptor 17inch wheels. No rub at all! Also not sure if it’s because the BFGs are C rated vs the nittos E rated or because there’s more sidewall, but these seem to ride a bit softer than the 295/70/18 ridge grapplers I had on which is an unexpected plus.
LOOKS PERFECT! you have a lift/level?
rathbunr5
rathbunr5
Bobby
Connecticut
rathbunr5
rathbunr5
Bobby
Connecticut
rathbunr5
rathbunr5
Bobby
Connecticut
does it have a levelkit? Glad to see a couple more setup with the 20” OEM
If it has 35x12.50 on it then it def has a level kit
Captain
Ryan
Washington
2021 F-150 XLT 5.0
Thank you! Yes this is correct, if you have the max tow package the rear brakes are bigger and 17 inch wheels won’t fit.
I’m super jealous of you guys that can run 17s.
