texag
CA
2010 Silverado
Does this update enable bluecruise? Still trying to figure out what’s going on with that but everyone from Ford customer service to the local dealer here in CA seems clueless.
petemill
Pete
Santa Barbara, California
'22 ER Lariat +PRB +Unleashed, '11 ford escape v6
Software
You absolutely can check your current version as long as there is no new update pending.
Settings - System Updates - Update Details
That will show you your current version number and release notes.
I'm Lariat Powerboost 502A and still on 1.4.0
apMechorse
Steve
Fargo, North Dakota
'21 Ford Lariat 5.0L FX4; '14 Chevy Spark LS
Aircraft Maintenance Manager
I don't suppose one of the "other enhancements" happens to include unlocking the bed camera over 6 mph, does it?
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Mine does not show that and I've had at least one update....
Lippy
CA
2021 F-150 Powerboost
In my XLT cluster, it’s much more descrip than that:
The arrow is all you get with Apple Maps/CarPlay. You get a more information on the instrument cluster if you use Ford built-in nav. And no, you can't use the camera in the bed while driving with this update.
mschiraldi
New Jersey
2021 F150 Lariat Sport 2.7 SCREW
It's just a little arrow and distance at the top.
Not super impressed with that integration, if you switch to navigation in My View does it show bigger?
EatDirtFartDust
Josh
St Louis, MO
2021 Ford F-150 XLT, 2015 Lincoln MKZ
Ford service manager
Ford F-150 Lightning Power-up 1.7.1 OTA Installed CF6BDADB-8AF0-4B88-BCEF-B361CDCD04E5
This is how my truck works as I drove it off the lot. I believe it’s a late build, so maybe that’s the issue.
I was using Apple Maps with CarPlay connected wirelessly for directions. I believe my truck has the factory navigation, but I wasn’t using it.
Lippy
CA
That would be good. I tried both the bed camera and full nav on the cluster and neither worked like yours.
