texag
Does this update enable bluecruise? Still trying to figure out what’s going on with that but everyone from Ford customer service to the local dealer here in CA seems clueless.
Mine does not show that and I've had at least one update....You absolutely can check your current version as long as there is no new update pending.
Settings - System Updates - Update Details
That will show you your current version number and release notes.
I'm Lariat Powerboost 502A and still on 1.4.0
Neither does mine, it simply states “System is up to date” and as far as I know I’ve had none.Mine does not show that and I've had at least one update....
What does CarPlay on the center stack look like? Got any pics?
It's just a little arrow and distance at the top.+1 for pics
In my XLT cluster, it’s much more descrip than that:It's just a little arrow and distance at the top.
The arrow is all you get with Apple Maps/CarPlay. You get a more information on the instrument cluster if you use Ford built-in nav. And no, you can't use the camera in the bed while driving with this update.In my XLT cluster, it’s much more descrip than that:
Same here. Gives no details at all.Neither does mine, it simply states “System is up to date” and as far as I know I’ve had none.
Not super impressed with that integration, if you switch to navigation in My View does it show bigger?It's just a little arrow and distance at the top.
I'll try later tonight when I'm back in it.Not super impressed with that integration, if you switch to navigation in My View does it show bigger?
Navigation view while using CarPlay is unchanged. It just says "See Touchscreen".Not super impressed with that integration, if you switch to navigation in My View does it show bigger?
