Power-up 2.1
apMechorse
Steve
Fargo, North Dakota
'21 Ford Lariat 5.0L FX4; '14 Chevy Spark LS
Aircraft Maintenance Manager
And here I am with my 9 month old 5.0 Lariat with not a single OTA update since taking delivery.
Early buyers of job 1 trucks really got the shaft on this one.
Reactions: Geo
BMWtoF150
Marty
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
Not sure why you would not be getting any OTA updates. My King Ranch was purchased on 12/30/20, so very early build and I have gotten all of the updates.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Stop bragging ;)
Mine is a march build and I've received the first couple of updates, but mine is stuck in limbo downloading the 1.7.1 update :cry:
It started downloading on the 18th and stopped after it downloaded 2.7Gb and now my software version and revision are blanked out in the sync software.
I now have to start my truck once a day or it will keep draining my battery.
I even tried manually installing the APIM update using FRDS and USB stick and it won't install. I really hope I don't need my APIM module replaced.
ryanc111
Ryan
Bozeman, MT
Leadfoot Powerboost
It could be worse . . . I received a notice last week that my Powerboost received an update - to 1.6.0. Then two days later I received an notice that I received another update - to 1.4.0.
I'm headed in the wrong direction. Ha.
tonesto7
Anthony
Yeah, whoever designed the rollouts dropped the ball...
I'm pretty sure 1.6.0 was the GWM module update which was required to fix issues with OTA and allow 1.4.0 to install the TCU module update.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Stop bragging ;)
1.7.1 requiring a 2.7GB download? That seems really large for what 1.7.1 does—updated the APIM. Something else must be trying to download as well. When I got 1.7.1 it installed very quickly—far faster than I would expect a download of that size to install.
JEB
Northern Illinois
I know 2.1.0 updated the GMW. If 1.6.0 also updated the same module that would surprise me. But I suppose it’s possible.
tonesto7
Anthony
1.6.0 is the first update to GWM. 2.1.0 is an additional update to likely resolve more OTA features and maybe stage for upcoming features.
I read somewhere that it allows the horn/lights button to display in the fordpass app as well.
tonesto7
Anthony
It's actually not nearly as large as it should be. The APIM module is what contains the SYNC OS and maps...
This update brings our Sync version up the latest code as of May. New trucks have a newer version than the 1.7.1 release.
I've seen it reported that the overall download size is approaching the 9+ Gb because of the map updates.
JEB
Northern Illinois
Something still doesn’t sound right. The 1.7.1 I received was nowhere near these sizes. It installed quickly and my Sync version did not change. The download I got had all the earmarks of a small firmware update. No evidence that it touched my OS. I would also expect an OS update of 3 GB or larger to require WiFi to download and 30-45 minutes to install.
tonesto7
Anthony
I'm not sure what to say... I'm extremely confident. I've spent a lot of time looking into this. I even follow the mach-e forums which that vehicle uses the same exact infrastructure as our trucks (minus the electric components)
The APIM is SYNC. I think ford made some changes to recent deployments of 1.7.1 because early rollouts of 1.7.1 were downloading almost 9Gb.
I just checked FRDS and tried installing the APIM update and it only downloaded 3.7Gb to the USB stick. It didn't include the map files.
The issue for me is that I couldn't even get Sync to install the files from the USB using to appropriate tool and license.
Maybe @Ford Motor Company can help?
mwf5888
Michael
Fort Wayne, IN
2021 KR PowerBoost FX4 & 2019 Escape Titanium
Lead Training Manager, Design
I am in a similar situation as you. This update failed a few times OTA so went to dealer, where it failed using USB stick. So, dealer ordered new APIM, which is schedule to be installed Wednesday, since the software at the dealer showed the install failing at the APIM each time.
Geo
Geo
2021 F-150, 4x4, Lariat 501A pk. 5.0 V-8, Max Tow.
i agree with you totally but i would go to the ford dealership on every thing you mentioned except bluecruise. I got my platium last january and it has all the above right off lot besides the blue-cruise.
You have the bed camera display while driving at highway speeds ???
JEB
Northern Illinois
I’m not doubting you. But I think the APIM is pretty complex and it might not be monolithic. I thought it was structured like a home computer with something akin to a BIOS and a separate flash memory to hold the OS and map data. You can update one without necessarily having to update the other.
BoilerTimmay
Tim
Indiana
2011 SCREW 3.5L
I have a 2 month old Platinum with BlueCruise prep package and I am missing out. I do not have many of the features that I see others have already including BlueCruise, turn-by-turn navigation from CarPlay, the ability to use my bed camera while moving, and probably 10 other features or fixes I should have.
I'm thinking it is YOU that does not understand how this should work, as a 2 month old $75k truck with advertised OTA updates should not be missing features.
You're missing the point. You bought a truck that didn't have those features, and they weren't promised. In years past, you didn't get anything that wasn't on the car when you drove it off the lot. It is a bonus to get updates that add features. I am in the same boat, you aren't missing much on the nav or camera. It will get updated in due time. If you really have an issue take it in to the dealer. The hard part is the disparity in the millions of possible configurations that are out there.
