RedTXV
2021 SQ Limited
If I scroll through this code to copy and paste one more time, and it doesn't, I'm going to throw this thing against a wall.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Try using the suggestion by Tonesto7 below:
There is a flag in the script code called clearKeychainOnNextRun that can be set to wipe all data.
Once you do that then change the flag back and you should get the login again. Or re-copy and paste all the script again after.
Is there an ez way to search on the iphone script for the flag? Code is huge. I tried adding a new version of the script and it does the same thing. So what you say could be the prob. Just not ez to find stuff in it.
BHunted1
Sumner County TN
Seems iphone doesn't let you cut and paste that ez.
jameswall0
James
Atlanta, GA
2019 Explorer Limited, 2022 F150 Limited
Senior Manager Tax
I would suggest copy and pasting the script into NotePad++ on compute then search for flag and note line number then go into the iPhone and it should be the same line.
I went ahead and did it and the setting is on line 116.
BHunted1
Sumner County TN
Fantastic! That worked great! Many thanks!
BHunted1
Sumner County TN
Can't get mileage to miles. Insist on metric. Won't change in settings....
jameswall0
James
Atlanta, GA
Senior Manager Tax
hmm, gonna have to defer to Tonesto7 on that one if re-doing the script doesn't fix it.
kb2755
Ontario, Canada
'22 F-150 XLT 302A Sport
I think it was suggested either in this thread, or somewhere in the documentation, but it's much easier to copy/paste on computer and save to iCloud Drive. I've been copying/pasting into TextEdit on Mac then overwriting the file in iCloud Drive, way easier than trying to do it on iPhone.
That being said, I'm getting a number of the errors others are having, but I think it's because I've severely jumped the gun and my truck isn't built yet! I'm in mobile product management, so this had me excited :p
JediNut
Emmett
Rocklin, CA
'21 Ford F-150, '05 Harley Davidson Softail Deuce
Personally, I make changes in the "iCloud Drive/Scriptable" folder on my Mac and magically... it is changed on my iPhone. :) (iCloud sync is a wonderful thing)
Codiferous
2021 2.7 XLT
This is pretty neat! However, I keep getting an error after entering my credentials and VIN: "Error on line 1814:23: Expected value of type string but got value of type null"
1813 and 1814 is
async function setKeychainValue(key, value) {
await Keychain.set(key, value);
Seeing as it looks like has to do with the Keychain, am I experiencing something similar to the others that have weird passwords?
dalmcrantz
2021 F-150
I’m in the same boat (or should I say truck). Mines built and in transit somewhere between MI and CA. I hope to get her this weekend. So I’ll wait till I can get the FordPass app connected and then I hope the errors will go away. But major kudos to Tonesto7 for all his work on this!
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Release v1.3.0
  • Modified the VIN field to store VIN as an uppercase string.
  • Added additional VIN format validations to setup prompt (Makes sure it's the right length and doesn't have any special characters).
  • Fixes and additional error handling for reported issues in the forums.
  • Modified the widget timestamp to reflect the last time the vehicle checked in and matches the last communication in the FordPass App (It's more descriptive now as well)
  • Added the ability to hardcode an id into the script to allow for multiple instances for multiple vehicles. See the SCRIPT_ID in the script header (Not fully tested).
  • Reworked the way all the window, door, and tire details are generated. They should now be laid out symmetrically.
  • Tire pressure numbers will change color based on different pressures states for low or critical. (see the widgetConfig.tirePressureThresholds parameter in the script header to define custom values)
  • Restructured the bottom of the widget to display events like low battery, deep sleep, firmware update, and any other errors. (It's also on a different line than the timestamp now).
  • Updated the widget generation logic to support the different iOS widget layouts [small, medium, large, extraLarge] (Actually layout changes coming soon).
  • Started working on the small widget layout working (needs a lot more work)
Download Link:
https://raw.githubusercontent.com/tonesto7/fordpass-scriptable/main/Fordpass Widget.js
Instructions:
tonesto7/fordpass-scriptable: FordPass Widget for Scriptable (github.com)
What's Next?
  • Slowing down on features and focusing on stability.
  • Working on small widget layout.
Community:
Discord: https://discord.gg/VPw3zw9v
JediNut
Emmett
Rocklin, CA
tonesto7
tonesto7
Anthony
This release seems to have messed up the "small screen" layout...
What iPhone do you have?
That doesn't look like the new code... The bars in between the doors/windows/tires are a table now and the divider would be perfectly straight.
I just tried this on my kid's iPhone 8 and it is formatted correctly.
Does it format the same if the widget is generated using the widget menu?
