pavementends
Dang this would be awesome on Android. Would love a quicker way to activate all Zone Lighting instead of having to dig into the FordPass app. Any plans to make this avail on Android ?
This is super bad ass. I had an older version from weeks ago. The installer made it super easy to update. You da man @tonesto7!NEW Releases:
Fordpass Widget (v1.4.0)
FordWidgetTool (v1.1.0)
- Fixed local vehicle data file to support multiple instances.
- Fixed data scrubber to scrub out relevantVin keys.
- Removed the low oil life warning for now.
- Menu optimization to reduce the number of menu items. Lock and remote start are now submenus and they are officially only shown to supported vehicles.
- Added Horn/Lights control to the main menu for supported vehicles.
- Fixed a lot of the text and image alignment in the widget.
- Reworked the small widget to not show text on labels with icons.
- Added door and window status to the small widget.
- Added a nicely formatted breakdown of the OTA data about the raw data.
Please note that you will need to run the installer again to update the widget tool.
- Supports updating multiple instances and managing the SCRIPT_ID value.
- It's now used to create and remove additional instances of the script.
- It can now remove and clean up all widget instances and their data.
Once the widget tool is updated it will popup a menu offering to update your existing widgets.
Download | Upgrade Link:
Ford Widget Tool Installer (tonesto7.github.io)
Documentation:
tonesto7/fordpass-scriptable: FordPass Widget for Scriptable (github.com)
Community:
Discord: https://discord.gg/VPw3zw9v
Anthony answered this in post #90 in this thread …What type of security concerns should one have?
Not sure what permissions the OP is getting from users by signing into this widget. Seems cool, but the skeptical side of me also has ?'s....
It's stored securely in the iOS keychain. I can't see anything!
Please review the script code so you can see everything it's doing if you are more comfortable
I’ve looked through the code and I’m comfortable using it. (If that matters at all to you)
I got a pop up in the FordPass application this morning stating that Ford was having authentication, and other issues this morning. Perhaps that is related.Just got this error. Noticed the fuel percentage being negative.
I love that the widget at least shows the last known data where Ford just gives me a blank page.I got a pop up in the FordPass application this morning stating that Ford was having authentication, and other issues this morning. Perhaps that is related.
At least you are getting updates.I just checked and my truck has 2.1.0 available. Looks like 2.1.1 will be available soon.
it’s nice to see that the OTA is starting to work more effectively now
