The Mach-e had a once a year check of the coolant and replacement at 200,000 miles.Mentioned cooling systems for motors and batteries. 2 separate systems. I have a ‘16 limited super duty and 20 limited super duty both diesels and those both also have 2 separate cooling systems with about 50 quarts of chemistry 101 that takes place every 15000 miles. One of the many reasons I’m all in on the electric future. Anyone have a clue as to the size of the lightening cooling systems, are they sealed, will I have to keep my test kits, how / where do you check…?
Similar to super duty but complete dump of both cooling systems at 105k miles if I remember correctly. That’s 16 plus gallons!The Mach-e had a once a year check of the coolant and replacement at 200,000 miles.
Replace at 200000 miles? That’s, um, very reasonable. ?The Mach-e had a once a year check of the coolant and replacement at 200,000 miles.
Yup - much smaller than you are used to as well. 2 systems - ~10 quarts for the HVB (ER models) and ~7 quarts for the motors / electronics (AWD models)Replace at 200000 miles? That’s, um, very reasonable. ?
Nope. At least in the chat questions made public. I asked two questions that were answered privately and did not show up in the public chat.Did they respond to any questions surrounding the limitation of ordering an XLT+ER?
I missed the live stream, so thank you for posting this, I’m up to date now!Here are the public questions and answers from the livestream (leaving out the MY22 production fiasco, see other thread):
FordUser: What are the dimensions. Wheelbase, overall length, width etc.
⮑Moderator: SuperCrew – Length - 232.7” / Track Width — Front/Rear – 68.1”/68.3” / Cab Height (Empty) 78.3”
FordUser: Does the Pro trim with tow technology package come with side mirror turn signals ?
⮑Moderator: Yes Lightning Pro Trim when equipped with the tow technology package with come side mirror turn signals
FordUser: Are there any improvement for the battery’s planned
⮑Moderator: Ford will continually look for ways to improve battery performance.
FordUser: I really don’t want a panoramic roof. Can I get one without that in an XL or Lariat
⮑Moderator: So the series are PRO, XLT, LARIAT and Platinum Moonroof comes in on the LARIAT High series. So you can get one without on PRO and the 510A series on LARIAT.
FordUser: sill the live streams be recorded to watch whenever
⮑Moderator: They won't be available for replay.
FordUser: Also I like the silver rims. Not keen on the black. Will we have a choice in the rims?
⮑Moderator: The rims are specific to each trim. Platinum is currently the only trim to offer the bright machined wheels
FordUser: Is bed same dimensions as standard F150?
⮑Moderator: Bed length (tailgate closed) – 66.5” / Width Between Wheelhouses – 50.6” / Max. Load Width – 60.3”
FordUser: What adjustments on on the base XLT passenger seat? I am not sure what the knob shown in the pics does.
⮑Moderator: The passenger seat is two way (forward and back) manual adjustment.
[Note, didn't answer knob question, I thinks it's lumbar]
FordUser: Regenerative braking?
⮑Moderator: Yes, the Ford F-150 Lightning does have Regenerative Braking.
FordUser: Question regarding the "HOOD" for the Frunk - Is there a switch on the exterior of the hood so that you do not need the key fob if you are outside of the truck - just like you have with trunk lids and lift gates?
⮑Moderator: Unfortunately there is isn't. You'll have to press the instrument panel button from inside or using the touchscreen. Also by using the SecuriCode keypad or key Fob.
FordUser: Can you use power strips plugged into the outlets?
⮑Moderator: A power strip will plug into the outlets. Keep in mind that each of the 120 Volt outlets is limited to 20amp output. Any overload would trigger the on-board circuit breaker
FordUser: Will the work surface be an option on the Pro trim?
⮑Moderator: As of now Interior work surface is not available on Pro trim models. It's standard on XLT, LARIAT and Platinum.
FordUser: Does Max Tow include anti-sway or extra stabilizer bars?
⮑Moderator: it does not.
FordUser: When longer range battery's become available will the 2022 Lightening be upgradeable?
⮑Moderator: The standard range battery is not upgradeable to the long-range battery.
FordUser: Does the F150 have 1 pedal driving?
⮑Moderator: Yes - and you can turn it off in the drive mode screens
Anyone else see Erroll push a button on the frunk to open it. Maybe I dreamed that.Here are the public questions and answers from the livestream (leaving out the MY22 production fiasco, see other thread):
Pretty sure he used the fob to open and a button to close.Anyone else see Erroll push a button on the frunk to open it. Maybe I dreamed that.
