ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
Is it possible to make mirror lights and bed truck light works while in motion by forscan?
Also how to enable DRL when the gear shift in Park position? Because it switch off when I put gear in P.
I have 2021 F150 Lariat 502A.
Any help guys will be appreciated
ROBB1
Justin
NC
2021 F150 Tremor
To the first part of your question: to my knowledge no one has cracked the speed inhibit on the lights yet. I have poked around, but came up empty so far.
For the DRLs: If someone has more knowledge on this please chime in.
Something you could try (not sure if it will have the desired effect) is changing the DRL conditions config.
BCM
726-38-01 xxxx xx** xx
00 = Option A
01 = Option B
DT444T
Jake
21 AMB Powerboost Lariat
Meat servo
I thought the same thing lol. Is it right hand drive? lol
My gf has confirmed that it is, indeed, the driver side mirror. It bothers me that they only gave it ONE auto dimming mirror.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
That is typical for the F150. Mine going all the way back to 2010, were all like that. I never get any glare from the passenger side, prob based on the angle I have it set, and tinted windows.
Livnitup
Livnitup
2021 F150 Platinum
FDRS showed an APIM/TCU update yesterday for my truck so I did it (took several hours) and now my Sync is at 21281 rev244. I briefly experimented today to see if I could get the Bed Camera (IOD) card working but still nothing. Will do some more experimenting this weekend and see if I can get some better results.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? sync update
heffer86
Iowa
2021 F150 Lariat 501A
I also was able to get my Sync version up to 21281 rev244 with FDRS. I now have camera's at speed also based on the following changes. I have a Feb 2021 build.
IPMA 706-02-02 xxxB CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-02 6xxx xxxx xx- (Tried it but I lost my camera menu "three horizonal bars". Went back to stock)
APIM 7D0-01-04 xxxx EDxx xx--
I haven't been able to get my Rear-View Split-view button (See picture) to work. I can tap it all I want and nothing happens.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1642739323800
miguel0oo
Miguel
Puerto Rico
2021 F150
I have the same question about the DRL’s.
Do any of you know if it’s possible to keep the DRL’s ON while the vehicle shift is in parking?
sysop
Joe
2020 F150 Lariat 145 - 2022 F150 Lariat 157
worker bee
On the last generation, it required a wiring modification under the steering column. From the explanation I saw, there is a specific circuit in the truck that only has power up to a certain speed and then shuts off. The wiring modification simply removed the mirror spotlights from that circuit and provided 12v all of the time.
I miss the 13th gen mirror spotlights. They were much brighter.
Canadianeh!
Marco
2021 f150 lariat
You are the man!
Based on this info I was able to enable Auto heated and cooled seats.
Seats automatically heat or cool based on internal truck temp and selected temp. You will also see a APIM display of your temp selection and whether you are in Auto mode or not. Manual control is retained via the buttons. I just implemented this tonight and everything seems works as expected in auto, but I haven't done any long term testing, so mileage may vary. You will need heat / cooled seats and auto climate for this to work.
My truck is a 2021 402A Tremor which is equivalent to a 502A Lariat. Other trims should verify your original as-build against the spread sheet for possible differences.
HVAC
733-01-08 xxxx x1xx xx (Original As-built 0)
APIM
7D0-02-02 1xxx xxxx xx (Original As-built 0)
How did you get that on the screen
Livnitup
Livnitup
2021 F150 Platinum
Please tell me someone wants to figure out how to have ForScan make this happen....
This is likely APIM, IPC, and ABS changes but it looks like the Tremor has additional ABS addresses that a '21 or 21.5 doesn't have and it has "Enhanced Memory" as default where my ABS doesn't so I'm skeptical of getting it to work. However, if you're wanting to try and have backups then I would try the following:
APIM 7D0-02-01 xxx7 xxxx xx-- reset APIM after this change
IPC 720-10-01 xxxC xxxx xx--
IPC 720-07-02 x7xx xx--
ABS 760-04-01 xxxx xxx1 x1--
EDIT: Just tried this in my truck and got the Trail Turn Assist slider to appear in Sync but couldn't turn it on so I suspect there's something else going on with ABS version/values
ROBB1
Justin
NC
2021 F150 Tremor
After making the the changes I listed in the post it will pop up when you press the seat heat or cooling buttons on the HVAC control.
antho
Anthony
Houston, Texas
2021 801A Raptor
My raptor doesn't have the rear split view at speeds. So im not sure your missing anything
EDIT- I just noticed you where reffering to the regular rear view and not the wide/split rear view like we can do with the front.
antho
Anthony
Houston, Texas
2021 801A Raptor
@Livnitup Did you have your truck in 4hi or 4lo when trying?
