Lightning FORScan HCM spreadsheet
'DRIVE MODE' modification - would like to 'default' the drive mode to 'SPORT', rather than 'Normal'...
any ideas?
BennyTheBeaver
2023 Lightning XLT ER
any ideas?
Been asked 10+ times, by 10+ people, and no.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
So, I did the Glare Free Headlight.
How the hell is this not standard on Every car in the USA? One of the best mods ever. Always flashing other trucks, thinking their high beams are on. Did the double horn delete. Seat belts chime off. AM radio activated. Great job on the codes, from all who wrote them up.
Tom Jensen
Arlington, Virginia
F-150 Lightning 2023
Attorney
I've just added a Lightning-specific HCM spreadsheet here: https://bit.ly/3waQ0tS
It came to my attention that some people were using values from the non-Lightning HCM spreadsheet for the Glare-Free Lighting mod but some of the addresses are different on a Lightning:
734-01-02 xxx1 xxxx xx-- Automatic High Beam Control Ramping
734-04-02 x*xx xxxx xx-- Bending Enabled
For the bending please try 1 or 2 and let me know which works.
I'm slightly embarrassed to have to ask this but am I right that the values in the far right column are the settings needed for the glare-free headlights?
You are looking at old instructions that are partial at best. For glare-free consult the main FORScan thread post 1. Also suggest you do a search in that thread only for "glare" to see the sucesses and failures folks have had.
https://www.f150lightningforum.com/forum/search/2653198/?q=glare&t=post&c[thread]=11406&o=date
Tom Jensen
Arlington, Virginia
Attorney
Thank you. I’m a total novice at this kind of vehicle brain surgery and need all the help I can get. I really don’t want to mess this up.
PAndaemonium
MY23 Ford Lightning XLT ER
So can I get a consensus on what the correct codes would be on a 2023? I used the original post … I have a lit green A icon and enabled glare free on menu
21st Century Truck
Martin
Tom, I see we're Arlington neighbors. If You have trouble setting headlight glare-free function just DM me and we can meet up. I turned my glare-free function on.
Robob
Rob
VT, USA
24’ Flash
Auto Parts & Paint/Body Supplies
Has anyone tested if the camera and map based dynamic bending works on US roads?
734-04-02 first bit set x4xx? I see in the glare free guide we don't change it, so I didn't try it yet.
Tom Jensen
Arlington, Virginia
Attorney
If you’re prepared to put up with a lot of rookie questions, I’d be delighted. My ability to tackle car mechanics with any confidence ended when I sold my 1967 Mustang GTA 40 years ago. It was all metal and no brains and I could see everything that could break. No more….I’ll DM you. Thank you.
21st Century Truck
Martin
"This will be easy" said the man at the beginning of the Appalachian Trail :crazy:
