Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
Thanks for this thread. Really, I mean that. Without it I might have thought only a guru should try this. But you laid it out so thoroughly that I felt plenty comfortable.
And yea, I never really thought you'd object to me sharing my exact experience.
Jesse-Infotainment
2024 F150 Lightning Flash
Hey great job snakebitten!!!! Like I said there doesn’t seem to be any real right way for this. I’m glad you got your truck squared away! I bet you feel better.
Snakebitten
Coastal Texas
It feeeeels brand new! (which is hilarious because it's still a 2021 with only 5000 miles)
My daughter thinks I have lost my mind because I'm trading the truck in as soon as my special order arrives. But that can take months! And besides, the next fella that owns this one will inherit a perfect truck. :)
And now that I have crossed that FRDS and Forscan bridge, I gotta admit that it ADDS to the enjoyment of owning one of these crazy computers on wheels.
Snakebitten
Coastal Texas
One final piece of advice. Do another network scan tomorrow in FDRS. There is another APIM update that should come down. It’s a small one that doesn’t require a flash drive.
Again, well done. Enjoy.
How do you gurus know all this stuff?
I'm going to go scan in a few minutes. I have just a few more hours of access license left. :)
I can see this becoming a bit too much "I wonder if there's anything new?" ?
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
You should have more time on the clock than that. When I activated my two-day license, it was more like three days. I got the day of activation plus two more days. Expiration appears to be tied to the date, not the time.
The APIM update to the update was a surprise. I didn’t know it was there. I just did a last-minute network scan before my license expired and it showed up. No voodoo guru Jedi stuff for me. If your looking for sorcery, that’s Jesse and Iceman territory.
Snakebitten
Coastal Texas
I scanned but only ended up with
As you know, those two updates are there even if you have already applied them. (twice ?)
By the way, guess what showed up today?
Ford F-150 Lightning ECU module programming guide using FDRS Screenshot_20220123-152628_FordPass
THIS is what I REALLY wanted!
Everything else was icing on the cake.
I'm a happy old man with all his "stuff" working now.
JEB
Northern Illinois
Cool! Glad Pro Power Bluetooth control finally showed up for you.
Thanks for confirming the GSM and ABS updates not clearing for you either.
Now that I think about it, the APIM update showed up about two days after I did the first update. It will probably show up tomorrow. Might not help you right now. You can catch it next time you decide to punch into FDRS.
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Yup I have the same, GSM won’t clear on FDRS as well under the SWupdates tab. Installed it multiple times.
TJSparky
WA
One question I do have is within FDRS my APIM update won’t run either… nothing displays on the screen… not even the “Do Not Remove the USB” warning screen your supposed to get. Not even after 1 hour of the vehicle running.
I did get update 1.6, then 1.4 automatically via the FordPass app notification about a month ago. I believe the 1.7.1 failure applies to me with not being able to select auto update or schedule updates etc.
What were the file names in your USB key made from FDRS? Mine have “14” in the name. Is this supposed to reference like ver. 1.4 in all of them??
Ford F-150 Lightning ECU module programming guide using FDRS 3EF8682F-5FBA-4B75-B331-117CB74A3A0A
iceman77
Pete
2022 Ford F-150 Platinum
I have the same. GSM module updated successfully, yet it wont clear in FDRS. I strongly believe its a bug on FDRS or Ford’s database side
Snakebitten
Coastal Texas
Thanks snakebitten
I'm keeping the USB drive in the truck to see if it eventually kicks off like others have mentioned.
My pleasure. I owe. Big time.
I noticed that your APIM update has a little bit different file manifest than mine. I would assume since FRDS reads the onboard APIM first, and then downloads the proper Payload for the update, that your truck requires a bigger jump than mine?
My truck had received the 2.1 OTA before I did the FRDS. I might have successfully gotten the 2.3 OTA if I were patient enough?
iceman77
Pete
If you recently updated your TCU and APIM, with APIM (SYNC) version showing 21283 rev244, you are running 2.3.0 OTA equivalent software
TJSparky
WA
Ya, my update package ended up being about 3.8GB.
