Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Any noticeable changes in Sync ? Did they fix the ACC SSR ? How is CarPlay screen look like ? I had a full list of bugs reported to them.
I need to look deeper and I'll post some images. FYI, I have Android Auto...
Bob_Mac
Bob
North Carolina
OTA or FDRS?
I hope this recent turn in the thread doesn't scare folks off too much. Just when there was amazing momentum to addressing trucks that were far behind in updates, suddenly it feels like the updating wasn't worth the risk.
Maybe I SHOULD be more worried but I can't find anything malfunctioning on my truck and I've done all the "scary" updates. Lol
And I haven't even figured out how to go check and see if my cloud is "corrupted".
I guess I need to go back and re-read the posts that I wasn't paying close enough attention to.
FDRS with the Mongoose. I've updated since my last OTA failed 2.3.0 and no issues other than the corruption.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Does anyone know what the 'DATA LABEL="706-29-### covers? It's the only area that some data seems to change daily. Runs from -01 to 201...
Ex:
<DATA LABEL="706-29-01">
<CODE>0A2B</CODE>
<CODE>08E6</CODE>
<CODE>A600</CODE>
Bob_Mac
Bob
North Carolina
Ex:
<CODE>0A2B</CODE>
<CODE>08E6</CODE>
<CODE>A600</CODE>
That's the IPMA
Bob_Mac
Bob
North Carolina
Ok, there are changes but, unfortunately the ACC SSR is still the same. No border around the Android Auto and phone details and weather are in the upper right corner of Google Maps.
Ford F-150 Lightning ECU module programming guide using FDRS 20220303_045335
Bob_Mac
Bob
North Carolina
@iceman77 just noticed something, ACC doesn't stick after a restart it's disabled. Also, the Send Feedback for Updates has now changed as seen below.
Ford F-150 Lightning ECU module programming guide using FDRS 20220303_045842
BHunted1
Sumner County TN
That's the IPMA
Thanks, should that data change every day? I still never get OTAs even since the new Apim replacement.
Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
TRM update in FDRS. I performed the update and now my CMDTC is clear. Took about 5 minutes for the complete process.
Ford F-150 Lightning ECU module programming guide using FDRS 20220303_133625
Bob_Mac
Bob
North Carolina
No, there's a problem with data corruption. Are you using the NANO?
BHunted1
Sumner County TN
I use the Nano but haven't in couple weeks. But been downloading and comparing ab files every day. They are changing in that area I mentioned.
Bob_Mac
Bob
North Carolina
Doesn't matter, the corruption was there when you used the NANO and each time you look at the AsBuilt data it will change.
JScaro
Georgia
2021 Ford F150 Lariat
Beer Drinker
Yes, please hold off for now.
@Bob_Mac @Jesse-Infotainment
OK guys, please keep us posted when this update is good to roll with.
I see the TRM update is out to correct the DTC and seems like I have a few other updates to do.
Since I only get the 2-day license want to get the best bang for my buck.
Jesse-Infotainment
2024 F150 Lightning Flash
So, A note about the IPC update. I have done it now and I have seen the OTA for thee IPC files.
Step one of the update is to install
Target IdentifierCurrent Software #Previous Software #File Size
Module: IPC INSTRUMENT PANEL CLUSTER
F120ML3T-14C026-CRCML3T-14C026-CDL186.03 MB
F188ML3T-14C026-CPCML3T-14C026-CCM1.84 MB
These were installed then there is a second part of the update.
F120MU5T-10F906-FDAML3T-14C026-CRC186.03 MB
F188MU5T-10F906-FCAML3T-14C026-CPC1.84 MB
Notice the previous files and the new files.
It went from the updated files to the newer files with the new middle part number
I believe everyone should be at the MU5T-10F906-FDA and MU5T-10F906-FCA
There are two steps to the update so PLEASE pay close attention while doing it.
I believe it is safe now. I did mine this morning and it went well. I have a V8. The first step was a USB update. AFTER the selecting the USB was successful it proceeded to the next part and it was CANBUS only it did not give an option. This is where the 10F906 files will be loaded
IF you get a error where is will not configure do NOT Panic. Just let it roll .. you can retry if you want but if you dont it is OK> Just follow it out
You will get a possibly DTC u2100 for initial config not done. This is OK it comes from the config not completing . Do a PMI. Select the original module is NOT installed and follow prompts.
Make sure to pay CLOSE attention to the whole process. Again it is TWO STEPS. The initial step gets you to the CRC and CPC the final is FDA and FCA.
I was able to recover the cluster that was blown and I am side loading the FCA and FDA level now. So if anyone had a issue dont panic it is savable. I had one completely blank! Its back to being fine now
