FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS)
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
New Release: v2022.02.27.0
For all us Forscan and AsBuilt junkies, I want to thank @iceman77 for the idea of displaying module-info :)
Under the Advanced Info page, you can now download your asbuilt data from Ford and it will display all of the module info and it's asbuilt.
Very nice update. Sent ya a donation from the script. ??
trojandawg3
Shannon
Northeast Georgia
2022 F150 XLT 302A FX4 SuperCrew 3.5 EB
Industrial Automation Specialist
Question...
In the notes is says it will auto update 3-5 minutes but mine seems to not be doing that. Is there a setting or option that needs to be turned on for that to happen?
Thanks for all the work on this!
JediNut
Emmett
Rocklin, CA
'21 Ford F-150, '05 Harley Davidson Softail Deuce
Question...
Anthony, please correct me if I am wrong here...
Note... there are two different values:
Last Checkin - This is the last time your TRUCK sent data TO Fordpass
Last Refreshed - This is the last time the widget refreshed the data FROM Fordpass.
Last checkin is labeled "Updated" in the widget and is above the "Unread Messages" banner in the full script display.
The "Last Refreshed" time is at the bottom of the full script display.
Hopefully this is correct... and makes sense. :)
trojandawg3
Shannon
Northeast Georgia
Makes sense. The "last refreshed" is usually within a minute or two. The reason I ask is because the widget itself is usually one to several hours since updated. I can get to work and lock the truck and look at the widget an hour later and it still says unlocked.
Just wondered if I have something set wrong so it don't update or is this normal operation.
skwrtle
Adam
www.flickr.com
2021 F150 XLT
Man, only time I've thought about a downside to having the android lol.. Sweet Widget!!!!!
trojandawg3
Shannon
Northeast Georgia
JediNut
Emmett
Rocklin, CA
I've seen my truck go 19+ HOURS between "check ins". :-(
ptricky
Texas, USA
2021 F-150
I just updated the official FordPass app on IOS to 4.12.0. Since the update, I keep getting a popup in the new app that my version of is expired (which is silly or buggy; I'm running what the App Store says is the most recent version).
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 5BAC22CB-DAE0-41D2-A216-6D88A48E55EC
More importantly - Is Ford pushing API changes that are going to impact the unofficial widget?
Bo15
Derek
NW Georgia
2010 F-150 Platinum 4x4
I updated it too but its working ok. And a bonus ... the message indicator finally went away!
antho
Anthony
Houston, Texas
2021 801A Raptor
Anyone using this app have onboard scales and smart hitch? If so, Does it show any info for either? TIA.
BLoflin
Brooks
Austin, TX
2022 KR PB 6.5'
Yes and yes.
To use Scales or Smart Hitch, need two things. Truck on (but doesn't have to be actually started) and Bluetooth connected. It does not work over Cellular connection.
For Bluetooth you have to be in range (less than 100ft, more like standing near the truck).
However, if you use CarPlay normally, then that basically turns BlueTooth off. So to use the app for Scales and Smart Hitch, you have to use the Sync screens to Turn on Bluetooth (which will ask you if you want to turn off CarPlay).
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
That's basically exactly it.
Last refreshed is the last time the dashboard was updated which also means the data was pulled from Ford.
The data refreshes between your vehicle and ford as spotty at best. Most days it updates in a few minutes but others it will go hours :|
trojandawg3
Shannon
Northeast Georgia
Thanks for the clarification. I understand now.
What would make the dashboard and the widget different though? Like the dashboard/app seems to be updated but the widget is not? Or am I just imagining stuff now? I am getting older lol.
tonesto7
tonesto7
Anthony
The dashboard I can control when it's updated. The widgets are at the discretion of apple to update.
I have a new version coming soon that may make the widgets a little more reliable
trojandawg3
Shannon
Northeast Georgia
I understand. Thanks for doing this!
