p52Ranch
Since the tires on the truck actually determine the 4th character in the VIN would it be possible to change tires after the VIN is issued? E.g. the all terrain tires on an ER Lariat or XLT result in a “V” in the fourth space. Where the all season tires on the same spec truck make that fourth character a “6”.Looking at all the available VIN's on the forum, the common element is indeed, the use of All-Terrain tires, they derate the GVWR by 150 pounds, regardless of the presence of Max Tow Package!!!!
All trucks with base All-Season Tires can carry 150# more.
Folks in Mass, please review your build sheet, if you have All-Terrain tires, and you show a GVWR of 8400#, consider deleting the tire option, go with stock All-Season through the build, this will bump your GVWR to a level that will qualify you (Tentatively) for the MOR-EV-TRUCK rebate.
