Fifth Wheel towing with the Lightning
Easycamper
Dylan
2015 F-150 XLT 5.0L, 2018 PacHy, 2013 Volt
Here’s where I plan to document my journey hooking up a fifth wheel RV to my Lightning. After considerable overthinking, I decided to give it a try.
We just purchased a Reflection 150 278BH. By coincidence my dealer is Can-Am RV of London, ON, which you’ve probably heard of if you’ve been around the Internets for a while. They just happened to have this model in stock so here we are. But if there’s any dealer that will help me set this up, it’s Can-Am. Here are a couple of pics I took of their other tow vehicles while I was there.
Ford F-150 Lightning Fifth Wheel towing with the Lightning BE01D3BA-49B5-44BE-991D-D7F54190A934
Ford F-150 Lightning Fifth Wheel towing with the Lightning 512A8DEA-A9B7-482D-AAEC-1AB2660A5294
I’ll be towing the Reflection with my 2015 SuperCab 5.0L (Payload 2030 lbs) until whenever my Lightning is ready. That will give me a good chance to check out all the weights, etc. and see how it handles for comparison.
After much research I’m confident that a hitch can be safely installed one way or another. There may never be a set of “no drill” hitch plates available for the Lightning, but a universal kit possibly with some modification will work.
This 278BH has an empty weight of 8500 lbs, a GVWR of 10,195 lbs and is advertised with an empty pin weight of 1300 pounds. It’s designed to be half-ton towable, so no bedroom slide and the heavy appliances are at the back.
NCMike
Raleigh, NC
2022 Red Lariat Lightning
I'm sorry, but any dealer that would hook an RV up to a Chrysler 300 or a mini van should not be trusted. Just because you can doesn't mean you should. I'm not saying you shouldn't use your lightning to tow a fifth wheel. I do believe F150s can be used for 5th wheel trailers safely if you are within all weight ratings and the vehicle is setup properly. I just would not trust a RV dealer to do this properly and within all weight ratings when they hook up RVs to mini vans and sedans.
Good luck!
vandy1981
Tennessee
Plumber
That fifth-wheel trailer will be about the worst-case scenario from an aero standpoint, aside from towing a parachute. I'm fairly confident that you will hold the record for the highest kwh/mile with that rig.
It will be an adventure, but please be safe.
Easycamper
Easycamper
Dylan
Thanks for the thoughts. Not sure where I’ll get the hitch installed or if it will be DIY. If I’m getting custom hitch work done, to me it makes sense to at least consider a place with over 40 years of experience with custom hitch work.
My range expectations are modest. I typically do only one trip per year over 150 miles / 250 km. Since 90% of my usage is closer to home I’m not really concerned about it.
May 20 is our pickup date for the trailer. First stop will be the nearby CAT scales to see what the weight distribution is like empty.
Easycamper
Easycamper
Dylan
Good news: The holes for the eight bolts that attach to the frame brackets are outside Ford’s “do not drill” areas.
The two centre bolts *are* in the no-drill area. These bolts just go through the sheet metal, and as I understand it are primarily to support the rails under the stresses of a slider hitch, which I don’t plan to use. So I’ll assess what the potential interference is and decide whether or not to install the two centre bolts.
Ford specifies a 2-inch gap between installed fasteners and HV cabling. For obvious reasons this will be important to observe or otherwise mitigate.
Ford F-150 Lightning Fifth Wheel towing with the Lightning 7713A791-9337-46CA-A43D-9C1135131ADA
Ford F-150 Lightning Fifth Wheel towing with the Lightning 4DF0E900-D9A4-4525-9715-0BB72888DE10
Easycamper
Easycamper
Dylan
Picked up the trailer yesterday. Took it straight to the CAT scale and verified the empty pin weight is 1350 lbs.
Ford F-150 Lightning Fifth Wheel towing with the Lightning CBC7AAA1-0097-4D6E-B6E1-1353066C5EF7
my thought is that there is going to be fifth-wheel manufacturers coming out with 'attachment plates' for the LIGHTNING, where a much larger 3/8" or thicker steel plate will cover much more of the bed, allowing for IT to be attached to the truck, then allowing the fifth-wheel mechanism to easily attach to IT, instead of the truck bed, itself....
VTbuckeye
Vermont
I am not familiar with 5th wheel mountings, but would a plate that exactly matches the bed shape/contour and uses the bed bolts (new bolts required for install) to hold it and the bed in place be sufficient to act as an anchor for the 5th wheel mounting. I assume that there would also be some accomodations for the 5.5ft bed and limitations imposed from the short bed. One of my coworkers has a sidewinder 5th wheel hitch on her camper on a short bed f150.
Easycamper
Easycamper
Dylan
Fifth wheel hitch rails are attached to the frame. The rails are thick steel channels that the hitch then attaches to. The bed has little strength itself, which is why I’m comfortable leaving the centre bolts off since they only go through the sheet metal.
Honestly I think the market for fifth wheel hitches for the Lightning is going to be too small for hitch manufacturers to invest in. I expect to be adapting a universal hitch mount.
This trailer has a Sidewinder on it. I’m not using it with this truck since the 6.5-foot bed gives be enough room to back the trailer at about 60 degrees to the truck, which is all I need. Not sure what I’ll do with the Lightning yet.
I don’t really like Sidewinders since they move the pivot point of the hitch behind the axles, which reduces stability. But the Lightning is so much heavier anyway (about the same weight as a gas F-250) that it might be an okay tradeoff.
TRP
Tim
TN
2021 Mach E Premium 4X, 2018 Ford F150xlt Sport
What hitch manufacturer are you planning to use?
I've reached out to B&W to see if they plan to offer a gooseneck hitch but at the time they had not seen a Lightning to make that determination
Easycamper
Easycamper
Dylan
I’m not sure. I likely won’t be towing until next summer so maybe something will be out by then. Otherwise it will be a custom job.
Reactions: TRP
rtk11226
Rusty
Houston Area,Tx
2023 Ford Lightning/1991 Chev 1500/1976 Corvette
Retired IT/Engineer
Any update on adding a gooseneck hitch to a Lightning? I see SUMMIT is listing a hitch for the Lightning… anybody have any experience?
Gerrard155
2021 Super Duty
I will never for the life of me understand the folks who try to 5th wheel tow with a half ton truck (not just EV's-any half ton). There is quite simply not enough payload to make it work and you will most definitely be exceeding your trucks capacities to try and tow that. I assure you you will be shocked how much additional weight goes on the pin once you start loading up the trailer.
Beyond payload-putting a giant 10K sail behind a 1/2 ton truck is asking for trouble.
If you are only going to be using this once a year-why such a large trailer (or a trailer at all)?
