Garage Parking the Lightning?
KristovM
CA
2022 F150 Lightning (coming soon)
For any of you lucky Lariat owners that have already received your truck, are you able to park it in the garage? What is the actual length and width measurement of the truck? How deep is your garage? I don't particularly want to park in the driveway, but have a feeling I might need to do that.
merek
Buffalo, NY
F150 Lightning Lariat ER [6/20]
I asked my dealer to let me test-fit an ICE F150. They let me take a used one for the day. It fit in my normal garage, but fitting two cars would be tough.
And the antenna is too tall, but that's an easy fix at least.
Yellow Buddy
Smart Ass
I bang that antenna against the ceiling warning thing of parking decks every time I rent one. Its an oh $hit moment every time…
I’ll be unscrewing my antenna when I get it
KristovM
KristovM
CA
Did you look at spec? 232 inches long, 80 inch wide without mirrors.
I probably did at some point but wanted some real world data points to compare to. If the 232 is accurate then I have only 3-4 inches of wiggle room. And that would block all walking around the truck.
kbuicker
Kevin
Dallas Texas
2022 Lightning
I found mine is about an inch +/- longer than my 2010 and my 2012 F-150. The centermost plastic portion of the rear bumper sticks out a little further with it's new design. That said, mine fits tight in my 3-car garage, but it does fit ( I've run to the back of the garage as the door closed 100 times). I park on the double car side, and had my wife guide me in the first time. Put tape on the floor and used that as a reference to lay down a 2x4 board with adhesive. I've found the garage door hinges are the actual problem. I'm looking for something to replace the one that gets way to close for comfort.
Ford F-150 Lightning Garage Parking the Lightning? FVkpBm3XoAIm9fh
Ford F-150 Lightning Garage Parking the Lightning? date 2022-08-29 at 12.54.51 PM
Ford F-150 Lightning Garage Parking the Lightning? date 2022-08-29 at 12.54.43 PM
Firestop
Firestop
I was really anal back in February when I placed my order….I 3D-modeled my garage in SketchUp, found a pre-drawn 3D model of a 2022 F-150 in their “Library” and test parked “my truck” in “my garage” multiple times…….BTW, I’m just a little analytical 😵💫
kbuicker
Kevin
Dallas Texas
2022 Lightning
Firestop
Firestop
I have a 90 deg curved driveway into our two-car garage tha can make pulling this truck in, so I also installed this (https://www.amazon.com/dp/B09XPCWFK2?psc=1&ref=ppx_yo2ov_dt_b_product_details) to help prevent me from sideswiping the passenger’s side of my truck when pulling in….the 360 camera system is nice, but having this aid helps me hug the right side and to not hog our double-wide garage……
Ford F-150 Lightning Garage Parking the Lightning? image
kbuicker
Kevin
Dallas Texas
2022 Lightning
Ew! A Gadget! :) I still have my red light green light unit from the 80s! :) This is cool. Maybe get one for my wife, but she would just side-swipe the opposite side :)
Firestop
Firestop
I bought two🤓🫥
Ford F-150 Lightning Garage Parking the Lightning? D6F0BEFF-F952-4514-8919-BB82F4F7956A
Firestop
Firestop
I bought two🤓🫥
I also have marked the concrete floor with tape to help….the blue painters tape (temporary, will remove) is the ideal location of the truck‘s wheel line (actual test fit). The 3M yellow marking tape (https://www.amazon.com/dp/B00AQ2AC50?psc=1&ref=ppx_yo2ov_dt_b_product_details) lines (will stay) is the offset from the above noted blue wheel line that can be seen by the truck’s 360 camera system (There is a shadow between those lines the cameras can’t see).
I use the yellow line with the truck‘s cameras to verify I’m over to the right and far in enough and aligned to give my wife enough room to park our Accord, and still have easy access in/out of both vehicles.
The location of the truck In the picture was how I parked on my first attempt, with no jockeying…..pretty close 🙃
Ford F-150 Lightning Garage Parking the Lightning? 757BD106-5587-489F-99C4-8D0DB0FC6B57
LUXMAN
F150 Lightning PRO and XLT
Pilot
OH thats cool! I may need one of these as I will be parking in the single garage door side and from my measurements, I will have to manually fold the drivers mirror every time to get in.
kbuicker
Kevin
Dallas Texas
2022 Lightning
I did this as well when I had to share with her Honda Odyssey :) . Had the truck in straight, and her angled off to the left. Worked great! No door dings either! She actually parked within the lines! :) I was shocked it worked as well as it did!
world2steven
tucson AZ
22 Lightning
