LightningShow
But Mythbusters...
This Ford design manager seems to believe tonneau does help with aerodymics.
But Mythbusters...
I’m going to lose 50 lbs and come back with range results before and afterif we're this sensitive to marginal increases/decreases in aero I think its a fair assessment that the lightning needs more range...
Nah, 500kw charging.if we're this sensitive to marginal increases/decreases in aero I think its a fair assessment that the lightning needs more range...
It works damned good on a bicycle.I’m going to lose 50 lbs and come back with range results before and after
This is meaningless. Actually, more than meaningless.With my tonneau cover open:
with it closed:
Just some anecdotal observations from driving in the real world. I have a tonneau cover for storage protection. I don’t think there’s anything I could do to my Lightning that would significantly increase its range. I’m enjoying it for what it is! It’ll be even better when everyone here gets theirs. It is worth the wait and the disappointments or let downs of ordering, production and delivery.
Show me anything obnoxious in anything I said. Just participating in a conversation. You lowered the conversation to disagreeable pal.🥱 no, you just felt the need to be obnoxious. But hey, that’s how social media works.
Apparently the only thing you wanted to look at is the images I posted. I clearly state I don’t think there is anything I could do to my truck to significantly increase the mileage. I have a tonneau cover for protecting my cargo in the bed. It’s just as meaningless as arguing over increase/decrease in mileage because of a tonneau cover. Why? Exactly.This is meaningless. Actually, more than meaningless.
Why?
Ford's EV driving data is known to be faulty. F-150Ls cannot get 5.4m/kWh unless they went downhill the entire 27.9 miles...
I tried losing 130 pounds but she insisted on coming along.I’m going to lose 50 lbs and come back with range results before and after
I was simply pointing out that Ford's EV driving data is not of value.Apparently the only thing you wanted to look at is the images I posted. I clearly state I don’t think there is anything I could do to my truck to significantly increase the mileage. I have a tonneau cover for protecting my cargo in the bed. It’s just as meaningless as arguing over increase/decrease in mileage because of a tonneau cover. Why? Exactly.
Yes, in an earlier post on the thread, I posted I had 101mi/kWh. Very obvious it isn’t accurate.I was simply pointing out that Ford's EV driving data is not of value.
Here's one of many screenshots from a Mach-E.
So at 127.3 mi/kWh, the Mach-E has higher efficiency than the F-150L....Yes, in an earlier post on the thread, I posted I had 101mi/kWh. Very obvious it isn’t accurate.
Maybe for now… maybe I can get that extra 26+mi/kWh with an AeroX fastback truck cap.So at 127.3 mi/kWh, the Mach-E has higher efficiency than the F-150L....
