Owners - Do you drive in one pedal mode or traditional ?
Do you drive in one pedal drive mode or traditional?
  • Total voters
    335
ChrisCon
The Hamptons, NY
I’m new to EVs but I’ve been driving f150s since a teenager . We rented teslas during vacations recently to get used to one pedal mode. I personally love it and I only have an issue when I jump into one of my super duty work trucks and have to forget my newly learned muscle memory .
So I’m wondering , what mode are you driving in and why ?
rlbussard
Ron
Army MSG Retired
I always drive my Mach E in one pedal drive. I'll be driving my Lightning in that as well. Hopefully here in a couple more days I will actually have it. It also saves from having to do brake repairs.
greenne
Nathan
Niskayuna, NY
I *do* think it is important to mention here that unlike Tesla Ford does have a blended braking system. You will get regen whether you choose to drive in one pedal OR lightly use the brake pedal. Obviously if you mash the pedal you will engage friction brakes when you pass the limit of max regen, but under normal circumstances you regen with the brake pedal.
It is my understanding with Tesla you have to use One pedal for regen, the brake pedal is strictly friction brakes.
(Someone correct me if I'm wrong)
sotek2345
Engineering Manager
Same,
My wife hates one pedal though, so I am glad Ford gave the option.
From what I have read online, being a current or former stick shift driver means you are more likely to like / adapt to 1 pedal driving better. It really isn't that different from engine breaking.
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Got used to one pedal in my wife’s Tesla. Also had to remember when I got back in my truck to use the brakes 😳. Much easier now switching between the vehicles. Still learning which mode is more efficient in the Lightning when it comes to regen.
rlbussard
Ron
Army MSG Retired
Same,
She should try to live with for a couple of weeks to get a good feel for how it works and then she might change her mind. It was very weird to me at first, but after a little while I got used to it and it became second nature.
sotek2345
Engineering Manager
I have tried, but she likes it the way she likes it. It is her car!
It flips back and forth with the user profile, so it doesn't really mater anyways.
FlasherZ
St. Louis Metro
+1... Tesla one-pedal driver here, never look back. Of course, manufacturers *can* screw this up by not having good "feathering" of the "go pedal" to represent various amounts of regen, but from what I hear from MME drivers it's not bad. I've heard it's not as good as Tesla's one-pedal blending of go-vs-regen, but very usable.
Skidrowe
Gideon
2022 F-150 Lightning ER, 2014 Honda Pilot
Many people have done range experiments in my electric motorcycle groups and have found that coasting when off the throttle results in a greater range per charge than allowing regen to engage when off the throttle. As a result many prefer the choice to have regen only engage when actively braking so as to allow coasting in all scenarios where they don't want to slow down rapidly or maintain speed.
When I get my truck, I'll prioritize my decision based first off of comfort and second off of impact on range.
yed19
Jay
Washington
'22 F-150 Lightning Lariat, 2012 RR Sport HSE
I have never had a EV before and was traditional for the first week. After reading a post on brake dust and the benefits of one-pedal I started to try it out more and now I try to do one-pedal the majority of the time. SO I guess I would consider myself one-pedal now, but its only been a week... I do not like when you are driving next to a line of cars that could easily try to change lanes going 30 with my foot on the gas pedal though... It feels off and less safe.
adoublee
Midwest
2 EVs
Agree, so one-pedal activated in stop and go traffic or otherwise many stop~starts expected. Otherwise off and stopping without mashing brake pedal. Lighting gives a regen score on the braking with every stop FWIW.
FlasherZ
St. Louis Metro
That observation all depends upon how you brake. If you typically come screaming up to an intersection where you apply the friction brakes hard, regen will be better (because any time friction brakes are used you throw away that energy). If you are the type to let off early and coast until you are slowly rolling at the very end, then it is true that maintaining momentum will save you. Regen in the best cars is only ~75-80% efficient.
I tend to drive my cars harder than others, so regen tends to help me more than no- or low-regen.
RainorshinePNW
Like @greenne said, in Traditional you still get some regen when you let off the accelerator at speeds above like 40 maybe. I find the One Pedal to be too aggressive for my typical routes, and actually get pretty consistent regen when letting off and just coasting.
Roy2001
Sacramento, CA
Tesla MX LR; Prius Prime
Driving Tesla with one pedal and I wish they can make it click when it is completely neutral so I can cruise - no accelerating (drain battery) and no braking (charging battery), just cruise.
2000Firehawk
2022 Lightning Lariat ER
I have gone full 1-pedal other than potentially on longer highway runs, although most of the time I leave it on there as well. It takes a minute to get used to, but works really well. It will hold the car stopped in traffic without a brake application and does turn on the brake lights.
