Charging history tracking via app?
JFIXIT
NJ
2022 F 150 Lightning Lariat Anti Matter Blue
VP Corp Ops
Is there a way in the app to track how many KWH of charging has been done in a specified date range ?
Reason I ask is I get compensated now for fuel and was thinking I would need to submit something showing KWH's of charging I used a month X my electricity charge of .14 per KWH
beatle
Springfield, VA
I'm guessing you're already familiar with the charge logs visible via the app, but there doesn't appear to be a filter for a date range, much less sum up your total kwh. If you do this manually, however, make sure to tack on about 10% to account for charging efficiency losses. I believe the kwh counts in the logs are what energy actually makes it to the battery, not what comes out of the wall.
I am hoping when Ford formally announces their E-Telemetrics service that it's not just for fleet owners, and that it offers reports like you're asking - or at least a way to export the data to a CSV so you can process the data yourself.
shutterbug
Phoenix
My ChargePoint summarizes the charges by month, and on their website you can download a table of individual charge sessions. I assume other "smart" chargers do something similar.
duncanmaio
Duncan
Norwood, MA
If you use a Chargepoint charger (I have a CPH50 set to 48 amps on a 60 amp service) for home charging, the Chargepoint web interface (not the phone app as far as I can tell) will give you detailed usage info and allows for downloading .csv files, sorting by date, etc.
Ford F-150 Lightning Charging history tracking via app? Document1
JFIXIT
NJ
VP Corp Ops
Thanks !
shutterbug
Phoenix
The app gives you summary, or you can go through individual charge sessions. The next 3 screen shots showing that in July I spent $4 on 80 kWh and added 245 miles using my home charger.
Ford F-150 Lightning Charging history tracking via app? Screenshot_20220802-101505_ChargePoint
Ford F-150 Lightning Charging history tracking via app? Screenshot_20220802-101514_ChargePoint
Ford F-150 Lightning Charging history tracking via app? Screenshot_20220802-101519_ChargePoint
jefro
F150, Corvette, Bolt EV,
Mine used to have some Free entries. Where did they go?
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
Are the free EA kWh delivered or received? I have 361 kWh left per Ford Pass but I didn’t look to see if I received 139.
beatle
Springfield, VA
The free EA kwh show up in the charge logs as all other charges do. You can also see the free kwh show up in your account messages. The messages on your account will start with "Fordpass Charging Bunded Reduced..."
