Mcalc55
F1504855
2022 Lightning Pro
hang on... you can't adjust the seat or you speaking of power adjustment?
It moves forward and backward at the seat level on the track (2 ways), and the seat back can move forward and backwards (2 more ways). So 4 ways total, hence “4 way seats”.
Worth noting that excludes any vertical lift. If you’ve been in a bronco or Jeep they typically have a lever you can pump up to elevate the seat. That’s not present here. Also the pedals don’t move in the pro so that also impacts seating position.
Does that help?
I guess for me personally I was very concerned about the limitations but didn’t find it to be an issue. The bigger gripe was the temperature of the vinyl
sotek2345
Engineering Manager
What do you mean? The lariat has great seats, I was referring to what they’re using in the Pro.
Which, for what it’s worth is much different from my bronco that had marine grade vinyl seats. Those are great
My mistake. The conversion turned to the Lariat seats for a moment and I forgot you have the Pro.
I apologize.
bmagn
bob
rochester, ny
Pro Lightning, 2005 TJ Wrangler
@Mcalc55 What floor mats did you put in? There are no retention hooks correct? Tuxmat says they only work with retention hook setups so I dont know what to get.
Thanks in advance.
Mcalc55
F1504855
2022 Lightning Pro
Thanks in advance.
I have tuxmat in there. I ordered a set of husky ones too but they have the spikes on the other side and I doubt they’ll stay put. I’ll likely return them. The tux do have the retention post holes but are form fit well enough they stay put
Yellow Buddy
Smart Ass
Regarding running boards, does anyone actually use them, or is it mainly for the look? The ones on my 17 F150 do nothing but collect road dirt - lots of it. The steel mounting brackets are rusting. I’m considering removing them.
ETA….don’t mind the haters. Sharing opinion through videos such as yours is valuable, especially to those without a truck yet.
I never use them, and get annoyed if I'm dressed up it ends up getting my slacks dirty. But my kids can't get in the truck w/o them.
bmagn
bob
rochester, ny
Appreciate it. Thanks. Do you have the front and back tuxmat?
Mcalc55
F1504855
2022 Lightning Pro
I do indeed. They fit pretty well with the exception of some folds look like they might be creases but it’s hard to tell. I think overall they’re great. I’ve heard if you reach out directly they can handle pieces that are creased permanently from shipping
Stlww18
St. Louis
2022 Lightning Pro, 6/3 blend date
Hmm, they told me they don't recommend them for the Pro since the lack of retention hooks presents a safety issue with the mat potentially sliding under the brake or catching accelerator.
Mcalc55
F1504855
2022 Lightning Pro
For sure a reasonable statement. I’m absolutely on board with that and remember the Simpsons episode where the grapefruit gets stuck under the brake in the school bus…
anyway I’ll take a look but there’s zero shifting cause it’s such a big mat and it’s form fit. I’ll include it in the next video :)
broncoaz
Cape Cod, MA
2021 Bronco 2 door Badlands manual
Both Ford and Weathertech offer mats for the vinyl floor. I don’t have my Pro yet, so I don’t know what is to isn’t there for retention. I’m going to buy the Weathertech mats and see if they fit when my truck shows up.
plucas005
Patrick
Massachusetts
MY23 Pro, Tesla MY
I know the Ford Pass hasn’t had full functionality yet but would be cool to see what capabilities you have on the Pro trim. Was kind of expecting that you would touch on it in disappointments.
Mcalc55
F1504855
2022 Lightning Pro
Actually that’s a good point. Wasn’t aware of differences until phone as a key was released? I can really just turn it on and unlock, turn on lights. Turn on isn’t really climate control like my tesla but it helps. What can others do?
plucas005
Patrick
Massachusetts
MY23 Pro, Tesla MY
Honestly not sure. Hasn’t been thoroughly covered from owners yet, at least from what I’ve seen. Would you include the capabilities you have with your pro in an upcoming video? Maybe you would inspire others to talk more about it.
would be cool to compare to Tesla app too… I’ll send my Venmo for a 10% cut on video revenue😉
monsterlag
AJ
Albany
F150 Lightning, Tesla Model Y Performance
not the Pro but it’s pretty similar on the XLT. Turn on/off. Lock/unlock and Horns. The app is positively spartan compared to Tesla. Turning on is what I do to pre cool the car before leaving work and seems to work great.
