Kirk
The $229 doesn’t look so bad so bad if we all click on his link.$229 for the LED oval ?
It took me to this:The link says for vehicles without front mounted camera
Yes, after the Ford "ACC20" Promo Code that takes 20% off. Expires 8/31.
https://accessories.ford.com/products/lighted-ford-oval-front-led-for-vehicles-with-front-camera
I tried myself. On a desktop it takes you to the correct "with camera" link. On a mobile device it takes you to the opposite....$229 after 20% discount yeah. I’m in but one quick question before I buy.. don’t we have a front camera? The link says for vehicles without front mounted camera
Putco is the same supplier that made the logo I used. Ford licensed it out to them =)Let's mix it up a bit - there are options if you don't like the one from Ford. This site says specifically they are designing a version for the Lightning. https://www.putco.com/product/luminix-ford-logo-led-emblems/
Well that stinks. I might have to return mineLet's mix it up a bit - there are options if you don't like the one from Ford. This site says specifically they are designing a version for the Lightning. https://www.putco.com/product/luminix-ford-logo-led-emblems/
It would be really cool if they made one to replace the logo on the Lariat+ tailgates.Putco is the same supplier that made the logo I used. Ford licensed it out to them =)
The only thing they need to swap is the T harness. Everything else is identical.
Intellibeam - that is what I ran into. Several little bits and baubles that I had to take off to figure out how the front was built and what could go where. But I agree, about 45 minutes or so and it's done.......but that's because people like you make the video. I will say that it does sound daunting, BUT it is not that difficult.It's actually quite simple. It probably took me 4hrs but that's because I was solo recording and taking pictures each step. Also, I had to hit Home Depot for a ground terminal connector that is absent from the kit and unscrewed some items that didn't need to be. If I had to do it all over again, probably 45min tops. I had to watch my own video back because I ended up with 2 extra poppers at the end. I'll have it posted here on Monday because of editing.
Yeah, if they swapped out that harness this would take about 12 minutes to do.Putco is the same supplier that made the logo I used. Ford licensed it out to them =)
I tried three times to export it today and after 3+hrs each fail, It's refusing. Some of the plugins we use are horrible and extended rendering times. I'm going to work on exporting another way in the morning.Where is the install video @Intellibeam
I don’t know about the front light bar, but I do know this: I removed the rear tail light assembly hoping to upgrade the reverse light LEDs as I would in prior F150s, only to find the new tail light assemblies are now sealed unit.Both the emblem and light bar need to be able to change colors as needed.
When you took apart the griil did you notice how the light bar is made? Wondering if someone will be able to replace the leds with multicolored led.
