adoublee
I believe there is still 9.6kW available for charging the truck from PV, but DC-AC to home wiring when grid-interactive appears limited to 4kW. Charging the truck through the DC EVSE connection would have to be able to be enabled in software though, and I am not sure that is being allowed out of the box. Ford has not said this works, but the Delta/Sunrun/Ford inverter shows this port to be bidirectional.It appears too small to include a solar inverter. The Ford / SunRun HIS solution has a Microgrid, keeping your solar on when the grid is down, and has a 97% efficiency of PV to EV charging, which is why I wanted it.
Sadly it went from a 10kW PV solution, to 4kW which is too small to run your house and charge your truck during the day, then running the house off the truck at night.
This was the feature I wanted out of the truck, and now I will wait for gen2 V2H solutions that are proven with MY22 Lightnings. I may be waiting forever.
