F150 Lightning FORscan thread
vandy1981
vandy1981
Tennessee
Plumber
Is there a good consolidated guide on FORscan usage for the newbies? For example, what must be obvious questions to someone who knows the app - in the "recipe" listed above, do you actually put "x" in place, or do you put the value your truck currently has? And when you save your settings, is it a full save / restore, or does it save only what was changed? etc.
I'm sure I can go hunting for it, but if someone has a great reference handy I'll take it!
See link in OP: https://www.f150gen14.com/2021/05/27/2021-f-150-forscan-database-spreadsheet/
FlasherZ
St. Louis Metro
I'll have to go play this weekend. I really like the glare-free headlight and DRL options.
jredondox
Jorge
San Diego, CA
2021 F150
i didnt get it to work for me :( shows on the menu but headlights dont do sh!t
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Will try tonight. Not 100% sure to test to see what it does. I get the concept.
jredondox
Jorge
San Diego, CA
2021 F150
vandy1981
vandy1981
Tennessee
Plumber
well I didn’t see lights move or get shorter 🤷‍♂️
The wig wag function (swivel) should still work when you start up the truck.
The glare free won't be apparent unless you're going above a certain speed.
I'll double check that I wrote down the correct settings in the OP.
jredondox
Jorge
San Diego, CA
2021 F150
please check is it supposed to be the same as ice trucks?
vandy1981
vandy1981
Tennessee
Plumber
The HCM settings are different. Everything else should be the same.
jredondox
Jorge
San Diego, CA
2021 F150
thank you! can you just verify the number are good? I will try it tonight again. Did you have to reboot each module?
vandy1981
vandy1981
Tennessee
Plumber
It sometimes takes a few power cycles and time for the settings to "take."
FlasherZ
St. Louis Metro
DRL forscan code from ice trucks work guys! I used the flashlight to simulate the sunlight and damn it’s bright!
EDIT: I had problems making glare-free and the light bar work, but figured it out.
You must reset the APIM after you're all finished and wait a couple of minutes, then everything should take!
jredondox
Jorge
San Diego, CA
2021 F150
on the ice trucks they change the ipc settings as well. Is it needed for ours?
vandy1981
vandy1981
Tennessee
Plumber
Oops, I left the IPC settings off of the sticky. I just added them now. @FlasherZ and @jredondox, try the updated settings and let me know if it works.
Are you modifying the brightness for daylight, when it's dark out or both?
jredondox
Jorge
San Diego, CA
2021 F150
