FlasherZ
- Mar 10, 2022
- St. Louis Metro
- F-150 Lightning, Tesla Model X, F250 SD diesel 6.0
EDIT: See below. I found the document I was looking for.So instead of using this massive battery as a buffer for demand, while mostly feeding PV to load (as most battery/PV systems do), they just cut the AC output from PV. Sad if true.
I had read somewhere that HIS charges the battery via PV DC (when grid down), that is a great and efficient workaround to the above problem (no AC output), but strange they did not get both load and battery power by keeping AC on.
It would seem that solar PV (which is joined on the DC side of things in the BDI) would still remain in operation, using the truck's battery as a buffer - but that on-grid feed-in is limited on the AC side of the inverter.
