jredondox
Jorge
San Diego, CA
2021 F150
Why'd you go with Xtreme for FL (right?)? Durability? Using them to launch people for cheerleading stunts on occasion?
I'm on the fence between Powerstep and Xtreme since I'm not in a cold weather climate.
I went standard San Diego weather is not harsh lol… fl should be the same
PungoteagueDave
That's the spec for the F-150 Lightning, dual motors. It is not the industrial version with the box running along the side (that's the XL). I am part time FL, part time in a rugged part of Virginia, on a farm, unpaved roads, dirt, sand.
pstansel
Paul
Tolland, CT
F150 Lightning Lariat ER, Hyundai EV6
Got a bedrug to install and ordered the torneau cover from Bakflip
jazzmanmonty
Lincoln Corsair
self employeed
Been debating switching to a electric mower. Our yard is small so the newer ones are perfect for us. I just hate to throw (or give) away a perfectly good gas mower. Maybe if I knew someone who was tight on cash and needed one.
Just put your old mower on Facebook marketplace and let it go for cheap to a good home. I switched to an electric mower 5 years. I have 1/4 acre pie shaped lot, and two larger mower batteries do the job for mowing and trimming. I have all Greenworks lawn tools and never had one problem in 5 year ago. They usually have good sales around holidays with extra batteries so keep an eye out. Spend the extra few bucks on self propelled too. Ok enough HGTV.
  • Haha
jredondox
Jorge
San Diego, CA
2021 F150
I wan these!
The guy at Etsy has the files, these were the first he created for the Lightning - I sent him files I found with the logo and lightning strike - he should still have them. I ordered these back in May.
I also realize my quick snapshots - I need to turn the lightning strike 180 degrees !
I honestly don't like the "T" as well, but that is straight from the logo, just blown up. It looks a bit out of proportion.
jredondox
Jorge
San Diego, CA
2021 F150
I contacted him already 🤣
  • Love
LightningLover
Silver Spring, MD
Mustang Mach E (E4X), F-150 Lightning (Lariat ER)
Those look good. I bought the same ones for my Iced Blue….I test fit them, and my wife was on the fence with the look. If I choose to install mine, do you have any installation tips?
Follow the instructions. Wash the tailgate. Let it dry well as there is a drip point from the plastic above the letters. When ready, use the alcohol wipe.
Lay out the letters to decide which way you want them to go (some can be used in either of two rotations).
Start with the smallest and easiest letters and get harder (hyphen, 1, 0, F, 5). Make sure they are aligned with the shape. Remove backing from a single long side and carefully put it in place. Peel off the rest of the backing and apply gently. If not much is stuck down yet you can pull off and re-align. When finished, press gently with soft towel.
Enjoy.
Galactus55
Gus
Ontario - Canada
OK this may look and sound silly. We live about a 1.5 hour drive to the nearest Costco. So when we go we make it a trip to visit family and friends near by. Even if we shop after visiting there is at least 1.5 hour sitting in the heat. We had my fathers old (vintage 1970) bar frig. sitting in the garage. Why not set it in the back and plug it in. It works flawlessly it's not the biggest or the best. But it is free.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? 1661787903709
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? 1661788072261
This is an old compressor frig. not bad on power we can run this thing for days.
BennyTheBeaver
BennyTheBeaver
broncoaz
Cape Cod, MA
2021 Bronco 2 door Badlands manual
I took a picture of it at the dealership. Some other lucky person’s Lariat is parked behind my Pro.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? 209867E8-68DA-4990-BCB1-9F97E8B7819D
