Passenger side hinged faux charging port cover. Anyone making one?
VTbuckeye
Vermont
The hood of my truck when parked is under a large shelf when in the garage. A 12V failure would be problematic. In my previous truck I could use the key to put it in neutral and push it back to get a battery charger on it. A port out the right side would be great.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
FYI, you don't need to remove anything from the frunk to jump your truck. They placed a positive terminal under the shroud on the passenger side between the frunk opening and the fender that is easily removable.
Appreciate the info.
aside from jumping, might be nice to also be able to disconnect the 12v for reboots when/if the frunk is either unresponsive or instead [frunk] is full of cargo (making it a pain to access the 12v panel)
Does the panel you mention allow you to disconnect the 12v, or it’s only a jump-post?
CNJKevin
Kevin
New Jersey
2017 F-150; 2020 EcoSport
RN
This may seem/sound stupid but why might I need to jump start an EV? (Please be kind; I really don’t understand.)
RavenYZF-R6
Denver
Tacoma
If you have issues with your small battery the truck may not turn on, drive, or even be able to put into the neutral/tow mode.
gsquirrel02
Andre
Hampton Roads, Virginia
2022 Lightning Lariat ER, 2020 Pathfinder
There could also be issues with charging. If the 12 v battery goes dead the HV battery won't charge. Everything in the EV runs off of the 12v battery other than the drive motors themselves. So it is still a critical part of the equation.
CNJKevin
Kevin
New Jersey
RN
Thank you for explaining that to me!
Is there an alternator that keeps it charged or is it charged as part of the main charging?
No spinning devices like an alternator. It is all done through electronics from the HV battery. The computer tells the truck it needs to charge. Contactors close and electronics step the voltage down and charge the LV battery. This can happen whether the truck is being driven or if it is sitting parked.
CNJKevin
Kevin
New Jersey
RN
Thanks again for educating me. This is so different than what I’ve known for the past 45+ years. My first car was a 72 Pontiac Catalina that ran on Regular Leaded gas!
gsquirrel02
Andre
I have my Bronco setup in FordPass to alert me by phone notification every time the door is opened. I also have an airtag mounted in the truck. If you are doing the airtag be sure to place it above the window line, range is significantly limited if it’s mounted where the signal has to pass through metal rather than glass. The C pillar above the window will be a good location for the Lightning. I use these Pelican mounts for the airtags.
https://www.amazon.com/Pelican-Protector-Stick-Mount-AirTag/dp/B09ZLW2PW8
Might be a great place to hide an AirTag for personal vehicle tracking, since Ford doesn't/won't do it.
