Charge Station Pro Charge Rate
mrcoolgli
James
2022 Ford Lighting Platinum
Ok so quick update. Been about a week or so since I last tried to change the charging rate from the APP. Tonight I tested and got the amber light and it works. I can dial it up or down and it responds pretty quickly. Maybe there were some updates or something before it would function but glad it does now!
Ffxdude
22 Lightning Lariat ER
Unfortunately I didn’t get very far. I get this error when trying to derate below 80A. I tried removing and reconnecting the CSP from Ford Pass but still get the same error.
A cycle of the breaker should fix that. When I first received my FCSP I was getting the overheating messages at 80a so I dialed it back to 60a via the app and it worked perfectly. When the software update was pushed to the FCSP I tried to put it back to 80a via the app and got the same message.
PV2EV
Just finished the install and it seems to be working. How/where can I check the actual charge rate?
Anyone know the current FW revision?
PV2EV
If you want to know the charge rate, you're probably going to need an ammeter. I know after I install my FCSP, I'm installing an Emporia energy monitor to know what it's doing.
Ffxdude
Thanks. I am on 2.112.64. Even though it seems to be charging, "Insights" shows 0 KWH?
That's what mine came with. Took about a week and it updated itself to the current version. Insights is hit or miss. Sometimes it's accurate and shows the kWh during the charge. Sometimes it doesn't. And sometimes it's slightly off....
Ford F-150 Lightning Charge Station Pro Charge Rate Screenshot_20221102-185023
The data server appears to be malfunctioning at the moment, it was working an hour or so ago but at this moment here is what I am getting trying to refresh my stat's, I wanted to look at how my current session was going, but can't at this time.
One of the weird things I have noted, the charge log won't register a session result until we unplug the truck in the morning, though the charging happened the late afternoon or evening of the prior day. The Charge station tile found under account in Ford Pass also only registers the performance data after the session is done and the truck is un-plugged.
Ford F-150 Lightning Charge Station Pro Charge Rate 1667502104945
Firestop
Firestop
I’ve noticed the same.
Also, I found I need to wait ~5-10 min after completion of the charge before disconnecting from the truck….otherwise, my FCSP indicator light goes White (FCSP resets) and it can take over a week for the charge session data (if ever) to show up in Insights in the FCSP iApp🤔.
My last charge session: ~91% efficient
FCSP app: 56.007 kWh delivered
FordPass app: 51 kWh received
Ford F-150 Lightning Charge Station Pro Charge Rate 087618B5-DC02-475C-8976-E60DE3B4C813
Ford F-150 Lightning Charge Station Pro Charge Rate 9E13B116-D809-4055-BC7E-1613DF5B1DD5
Arrington.LCA
Luke
Colorado
Does the “Charge type” always list AcBasic when everyone is using their FCSP?
I’ve had the same home network connection issues and been through a handful of factory resets. Finally while I was initially connected to the FCSP (before trying to connect to home network) manually added FCSP to Ford Pass app. Seems to be getting information on my charge sessions, but was curious about if it will display anything else for the charge type. Still need to try and get connected to home network so it can get updates. Will keep trying various setups and restarts to try and get it to complete.
