granfaloon
I have a base Pro model with no options ordered, and my window sticker lists the tires as 275/65R18 BSW ALL-TERRAIN TIR, does anyone know what tire that refers to specifically?
I'd like to know this, as well.I have a base Pro model with no options ordered, and my window sticker lists the tires as 275/65R18 BSW ALL-TERRAIN TIR, does anyone know what tire that refers to specifically?
I vaguely remember reading about a similar issue recently. I wouldn't sweat yet.Over the weekend I was showing built status and date of 11/5 on both the Ford Tracker and Ordertrack.app websites, and received the built email from Ford yesterday.
Now when I look at any of the tracking sites I'm back to "In Production", but the Ford site still shows a built date of 11/5 even thought that bubble isn't filled in anymore. Hoping its just a web glitch
Mileage on the same tire new vs used is even measurable, I bet if you had the money for it you could get a decent boost to your range (I'm gonna SWAG it at 5%). Also, I've never owned high efficiency tires but I've driven a car with them, I won't sacrifice my snow performance for mileage. They sucked in the snow, but I do understand it is only 1 data point.I'd like to know this, as well.
ALSO, I'd like to know if there are any other tire options in that size that would meet the load rating and maybe get some more range than the ATs on the Pro. The AT vs All-Season tires on the Rivian makes a pretty substantial difference.
Assuming 2023 is same as 2022: Michelin Primacy XC - Size: 275/65R18I have a base Pro model with no options ordered, and my window sticker lists the tires as 275/65R18 BSW ALL-TERRAIN TIR, does anyone know what tire that refers to specifically?
thanks, but looking at those tires, they look to be all season, not all terrain. I don’t really mind either way, I won’t be replacing them until they’re worn out. I was just curious because I wanted to check out the specsAssuming 2023 is same as 2022: Michelin Primacy XC - Size: 275/65R18
https://www.f150lightningforum.com/...at-brand-and-model-are-they.12040/post-254633
Edit:
I don't think replacing new tires with "more efficient" ones will ever make sense financially.
I won't actually change them, probably, but I'm just interested.Mileage on the same tire new vs used is even measurable, I bet if you had the money for it you could get a decent boost to your range (I'm gonna SWAG it at 5%). Also, I've never owned high efficiency tires but I've driven a car with them, I won't sacrifice my snow performance for mileage. They sucked in the snow, but I do understand it is only 1 data point.
You have me doubting myself but I am fairly certain these are the AT tires.thanks, but looking at those tires, they look to be all season, not all terrain. I don’t really mind either way, I won’t be replacing them until they’re worn out. I was just curious because I wanted to check out the specs
Michelin says they're ATs.You have me doubting myself but I am fairly certain these are the AT tires.
https://www.discounttire.com/buy-tires/michelin-primacy-xc
Thanks for confirmingMichelin says they're ATs.
https://www.michelinman.com/auto/tires/michelin-primacy-xc
Developed in conjunction with the world's leading truckmakers, Michelin launched the MICHELIN® Primacy™ XC tire to deliver not only light All-Terrain performance, but also a quiet and comfortable ride on-road and excellent fuel efficiency.
The pure money ROI wouldn't be good, but if it was good for 20 miles of range (Rivians are seeing way more than that), maybe it would be worth it if someone was doing lots of long trips or towing or something.Edit:
Interesting, thanks. Tire rack had them listed as all season for some reason, unless I looked at the wrong tire. Thanks for confirmingMichelin says they're ATs.
Same here, your not alone.Over the weekend I was showing built status and date of 11/5 on both the Ford Tracker and Ordertrack.app websites, and received the built email from Ford yesterday.
