Defect Report - Trips missing from My EV Driving history.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Defect report for @Ford Motor Company:
When I check "My EV driving" in the Ford Pass app, there are some trips missing. I have been commuting to and from the office Tuesday, Wednesday, and Thursday this week, but there is no morning trip on Tuesday.
Also, I noticed the mileage is incorrect for my trip into the office this morning. The distance is 15 miles, but the My EV Driving reports it as 30 miles. and calculated the efficiency at about 2X what it should be at 3.6 mi/kwh (should be more like 1.8 in the cold).
This is a software defect somewhere in the truck, the App, or the servers behind the scenes. Please get his defect on your software team's backlog to fix. Thanks.
VTbuckeye
Vermont
You aren't the only one with missing trips. Mine gets more than half, but not much more.
Jer
Jer
Oklahoma
‘23 Lightning Lariat,‘21 Bronco, ‘17 F350, ‘76 K20
Same here. Just skips trips for some reason. For sure hit or miss.
It has been hap hazard at best, but several of us have discovered that the Ford Pass only reports when you clear this trip, and to clear this trip, you need to keep your foot on the brake while switching off the truck at the end of the drive segment.
Unfortunately after updating android mobile with FP 4.23.0, it's not giving me any report for this evenings drive, even when following the above process. Banging head against wall
luebri
Neenah, WI
Dolio
Ryan
Tacoma Region, Washington
youtu.be
2023 Lightning Lariat ER Max Tow Carbonized Gray
That's interesting. It makes me wonder if/which OBDII dataloggers folks have been using with their lightning? Can anyone point me the the appropriate thread(s) for that topic?
Firestop
Firestop
Rbert
Richard
Hillsboro, OR
2022 Lightning, Tesla model S
I have noticed this too. I thought software updates would fix this, but not yet. I drove two 80 mile segments this week, neither of those trips showed up, but 10-15 mile drives show up. Maybe Ford will figure this out soon and software update it?
Did you do preconditioning or remote start to warm up the truck immediately prior to the long trip?
It seems that when I allow for a 15+ minute delay of departure, waiting past the programmed departure time or when the remote start session stops, the trip data is more likely to be logged. The times I forget to build in this buffer, then I usually see a missing log entry.
IMHO Ford needs to iron out the logic glitches with this issue once and for all.
Mine are still very haphazard. I trying to always take my foot off the brake, apply parking brake, and then turn off, but even then some don't show up. Or I'll fail to have the My Trip reset, and it will log a double trip. I always go in and delete any log that looks like it has bad data. I think it uses an average of those in the GOM estimate. My estimate went down after a couple road trips that dropped my avg m/kWh. It's been about a month since then and I'm seeing a bigger range estimate again.
