Griddlez
- First Name
- Griddlez
- May 20, 2021
- Metro-East of St. Louis, MO
- 22 Lightning Lariat ER - 21 Mach-E Prem AWD/ER
I can check this out too but the sound so far has lined up so perfectly with when the damn deploys (and how it deploys)... and the fact I removed the deployable part of the damn and the sound stopped all together.Looking at the shutter system, its definately possible that those shutters get stuck open and then start to vibrate at higher speeds or maybe one or two fans get stuck open. Not sure why it would happen... Seems like that is what has caused noise and vibration in the other threads though
Doesn't mean it's not these per say as it is either the damn itself or where it is redirecting air when deployed that is causing the sound. If it's redirecting air here and it's not functioning correctly then it could indeed be here.
Here's the video of a 45-53mph run just now. Sorry for the wet-road noise - I might need to do this again when the roads are dry to get good audio. I didn't particularly see anything wrong or and I am not sure on the sound it's making.. too much wet-road noise I think; it's a little clear later in the video (second deployment). I did still hear it in the cabin, just like normal.
Next thing(s) I want to do is record the interior noise for reference and perhaps mount the cam looking into the wheel well .. not sure how I can get a good angle on that tho but can try.
