Build orderI wanted to try to find a better way to pin point exactly what trucks might be affected and in need of a battery replacement based on the vins found in the recall notice. As you may know, the last few digits of the vin do not necessarily tell you the order in which the trucks were built. So you could have a vin with a higher last 5 digit vin that was built before a truck with digits that were lower. Of the window stickers that are still available, they all have a blend date between 1-22 and 1-25. Unfortunately, there isn't a lot of data to go by as only 5 trucks still have their stickers available, but with that information, my theory is that the date range of 1-20 to 1-26 in the recall notice refers to the blend date. Meaning that if your truck has a blend date of before 1-20, your truck may not be affected.
Here are the vins that had an available window sticker and their blend dates:
1FTVW1EL2PWG11054 01-241FTVW1EL5PWG11047 01-251FTVW1EL7PWG08599 01-221FTVW1EL8PWG08143 01-251FTVW1ELXPWG07639 01-25
