Tire Rotation - How?
drummer
Ankeny, IA
2023 Tesla Model S, 2024 Tesla Cyberbeast
Hello,
Has anyone rotated their own tires? Since there is only one jacking point per corner on a Tesla, I bought some special stands https://jackpointjackstands.com/ that allow you to jack the car up on a plate that is designed to then set down on a special jack stand. The jack stand is too short for the Lightning. I could probably get a normal jack stand on the frame rail next to a jack on the front of the truck but that part of the frame rail isn't double walled next to the jack point. Since the truck is so heavy, I'm fearful or setting it on the stand outside the specified jacking point.
Appreciate learning about your experiences either doing it yourself (which I have always done with all my vehicles) or on taking it your dealer.
Thanks,
Ford F-150 Lightning Tire Rotation - How? IMG_3470
Amps
Bolt
I saw a post somewhere mentioning that AAA's 18" rolling floor jack was too short when they came to their home to fix a flat.
astricklin
99 Mercury mountaineer
AAA contracts with individual service providers in each town. I would complain to AAA about that service provider. The lightning isn't any taller than any other f-150 and certainly has less ground clearance than many other vehicles. That service technician needs to have proper equipment.
BEVolution
Arizona
Model Y adding Lightning
Maybe engage your spare tire as part of the rotation so you only need to lift each corner once.
VTbuckeye
Vermont
Snow tires on separate wheels...Easy peasy, just have to label where they came from. Otherwise use the spare.
ssmegapunish
Colorado Springs
2022 Lightning SR, 2021 F-350 DRW CC, 2022 Bronco
Electrical Engineer - I do power grid studies and program the equipment that runs it.
Ditto on using spare/snow tires - that's what I do. I'm sure I could fit a jack stand and bottle jack in there if wasn't room for a normal floor jack. You can also buy hydraulic jack stands that have a "safety lock" too...example of a cheap Chinese one below.
Amazon Hydraulic Jack Stands.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
@Discount Tire offers free rotation even if you didn’t buy the tires from them (as in the case with original equipment tires). They even offer Certificates for Repair, Refund or Replacement on OE tires. Think it was about $200 for the 18” Michelins on my Pro.
We appreciate your support, Lee and thanks for calling this out!
Rotation service is always FREE at Discount Tire for passenger cars and non-dually light trucks, regardless of where the tires were purchased or installed. We can extended our Certificates for Repair, Refund or Replacement on O.E. tires as well, after an inspeciation.
