Lariat SR & Ford In-Dash Brake Controller
Dan_G_Lightning
Dan
Haymarket, VA
Network Engineer
ExCivilian
'05 RAM 2500 5.9L Cummins; '22 Lariat ER
I used one of these for years with my VWs. I still have one in my garage that I don't need now that my Lariat the controller already. I'll list it for sale eventually but feel free to message me if interested.
Bmann
Braden
2022 lightning
I have an XLT ER with Max tow package. I bought a dash switch for the brake controller from eBay. I then used forscan to enable it and now it works. I followed these two YouTube videos:
mattb
Matt
CO
2023 F150 Lightning XLT
thanks! what is the part number for the in dash part that you bought?
Bmann
Braden
2022 lightning
I bought this more than a year ago from eBay.
Ford F-150 Lightning Lariat SR & Ford In-Dash Brake Controller 8216F18C-39CC-435E-AF4A-C84F02F06891
Ford F-150 Lightning Lariat SR & Ford In-Dash Brake Controller 15D6EBEC-953E-470F-B66F-88D172C2131E
Bmann
Braden
2022 lightning
I noticed there are different part numbers from ford for the trailer brake control kits depending on if you have back up sensors, so I made sure mine came from a truck that had backup sensors.
Bmann
Braden
2022 lightning
Ford F-150 Lightning Lariat SR & Ford In-Dash Brake Controller 4DAB1C9E-D22A-4D15-AC2E-216614CA021B
Bmann
Braden
2022 lightning
Dan, I’m glad that worked for you! I thought mine was working fine, but when I actually connected to trailer and squeezed the slider, I get a trailer disconnected error. I tried it with two different trailers. Have you tested yours with a trailer yet?
Dan_G_Lightning
Dan
Haymarket, VA
Network Engineer
Uh oh.
I will hook my trailer up this weekend and try it. The saga continues...
mattb
Matt
CO
Uh oh.
Yikes. Hope it works! If not, maybe there is something additional to do with forscan.
Bmann
Braden
2022 lightning
Damn!
I'm contemplating taking it to the dealer to see if they can get mine working.... but I'm going to keep searching forums etc... to see if I can find any other ideas first.
I'll let you know if I figure anything out. Keep me posted if you have any success. What is the part number of your dash switch?
dovetaildan
2022 F150 Lightning
So both installed just the switch and it isn't working? But ML3Z19H332AB kit has both a switch and a brake controller module right? One option might be to order this kit and then trying to install both the switch and controller module. I bet it would work then. Might have to reconfigure that Forescan setting once you install the new parts.
I guess the issue is that the kit is on backorder so you want something now.
If you are pressed for time you could always try something like the Curt Echo (just uses bluetooth via your phone to adjust your brake controller).
