Has anyone else noticed that when AC charging with the Ford Charge Station Pro or other AC level 2 chargers the app no longer shows the charge rate in addition to the other bugs with this recent update? Running FordPass 4.27.0
The rate only shows while the charger as actively sending energy to the truck.
Waiting for 4.27.1 to hit the Android play store.......
GingerBear85
2023 F-150 Lightning Lariat ER - Stone Metallic
Construction
I got the download while away on a trip and noticed ford pass wouldnā€™t connect. I tried pulling #32 fuse, reloading the app, and disconnecting the neg terminal with no luck. I left it set for a couple hours and it went into deep sleep mode. When I returned I had to start it manually. Itā€™s currently working but showing less range at 90% than before
Same thing going on here, mine thinks it needs to go into ā€˜deep sleep modeā€™ after only being stoped for just under 2hrs?!? I couldnā€™t even get the doors to open with the PAAK! Thankfully I have the door key code programmed and once inside the truck seemed to find that manual crank none of us knew about and allowed me to start with PAAK. @Ford Motor Company this could be a real disaster if someone doesnā€™t have their physical key with them or a door keypad! Thankfully I was still at home and was able to dust off the key and take it along for my commute today.
Ford F-150 Lightning FordPass 4.27.0 update IMG_3627
RTanton
Russell
Mission Viejo
2022 Ford Lightning Platinum
Several times when I opened my Ford Pass app this screen appeared. I thought, incorrectly, there must be a problem with my Lightningā€™s charge port. Ford politely informed me that the message referred to my Apple phoneā€™s charge port not their vehicle. They need have plenty patience do deal with type inquiry. I look forward to Apple replacing their proprietary lightning connector with usb c later this year.
Ford F-150 Lightning FordPass 4.27.0 update IMG_0728
