FCSP to Tesla Adaptor (pics from Reddit)
Roy2001
Sacramento, CA
Tesla MX LR; Prius Prime
Original post:
According to Reddit OP CharityAny5289:
1) Remove the bottom plastic bit from a J1772 adapter (I used a saw to saw it off) 2) Change the amps in the charger station setting to 40a down from 80 (I think Tesla can take max 48 via ac)
When it was set to more than 40A, the ford charger would “click” 5 or 6 times like it’s starting to charge and then the Tesla would say charging stopped without any error messages. The longest it would charge is for a few seconds before the charger clicking and the charging stopping.
Ford F-150 Lightning FCSP to Tesla Adaptor (pics from Reddit) 7034c82511c6a1b0b9861ba3e1e73710
Ford F-150 Lightning FCSP to Tesla Adaptor (pics from Reddit) 81ee0ac4a773df67bebdd9c0967e96b0
Ford F-150 Lightning FCSP to Tesla Adaptor (pics from Reddit) 3a225f77dd7e64c3bd9363b40b6c8dea
Ford F-150 Lightning FCSP to Tesla Adaptor (pics from Reddit) be3c3dc2e5cc979d968be86d9ac363b5
FCSP to Tesla adaptor
SmoothJ
New Jersey
2021 F150 HEV
Roy2001
Roy2001
Sacramento, CA
Zaptor
.......... Trophy husband
Jesus, they butchered that cut lol... definitely not a surgeon's work. Do we have confirmation that this works before I (much more cleanly) attempt this? Does FCSP amperage need to be reduced from 80A? TIA
Vehicle onboard AC/DC converter determines [PULLS] how much it want to take from the EVSE, it will only pull what it wants.
Ex1, the car/truck asks or only has the capacity to draw 45 amps, then only 45 amps will flow from the EVSE, the remaining 35 amps of unused capacity is not forced into the car/truck,
Ex2 unlike a one inch water pipe with 200 psi attached via a 1/2" hose to a plastic garden sprinkler, now that might blow apart under such a force.
Zaptor
Thanks, I thought that was how it worked, but when I tried the "correct" adapter from Amazon (~$150) it clicked a couple of times then shut off, no support from the seller and just can't figure out how to charge MYP direct from FCSP... currently daisy chaining FCSP->Lightning->Tesla and that does work, although less than ideal... thanks again, still looking for the solution to not have to install a second wall unit (or charge the MYP on 120v).
Roy2001
Roy2001
Sacramento, CA
I did not see this so I am posting. I saved the picture but couldn’t find the OP on Reddit and couldn’t give him the credit. According to him, FCSP amperage needs to be set to 40A, otherwise Tesla would refuse to charge.
I'll heed the advice of experienced Tesla owners, odd that it would refuse to charge even if the EVSE could provide more current than the cars converter could process.
Roy2001
Roy2001
Sacramento, CA
Reddit OP has both and that's why he was cutting the adapter. He also had wifi connection issue with his FCSP so he hard set the current to 40A but not with Ford app. When it was set to more than 40A, the ford charger would “click” 5 or 6 times like it’s starting to charge and then the Tesla would say charging stopped without any error messages. The longest it would charge is for a few seconds before the charger clicking and the charging stopping.
I know Tesla vehicles should be able to accept more than 50A and limit current to 48A, since this is J1772 with adapter, so no one (with Ford/Tesla) will ever try to debug this protocol issue.
Nick503955
Nick
San Diego, CA
2023 Ford Lightning Lariat, 2021 Tesla Model Y
I finally got around to picking up an extra J1772 to NACS/Tesla adapter. I butchered it up and it worked!
Ford F-150 Lightning FCSP to Tesla Adaptor (pics from Reddit) IMG_4543
Ford F-150 Lightning FCSP to Tesla Adaptor (pics from Reddit) IMG_4545
Monkey
Somewhere in the mountains
Should not need to set the amperage lower on the FCSP, but it also seems to be a flakey charger, so...
The Tesla J1772 adapter included with the vehicles allow for full comms pass-thru and the car will request its nominal amperage. The Tesla adapter is limited to 60A, which could be the culprit depending on which Tesla he's trying to charge from the FCSP. If it's an older Model S with dual chargers or Model X with the high-power charger, then the cars would request 80A and 72A, respectively and those need to be dialed down at the charger or on the interface in the car.
Nick503955
Nick
San Diego, CA
I didn't adjust the amperage. Tesla requested 48a. Charger delivered.
Nick503955
Nick
San Diego, CA
Update: the Tesla started having trouble with scheduled charging. If I connect the FCSP to the Tesla and started charging immediately, it works. However, if I leave it connected for a period of time, it will fail to charge.
I'm thinking I will swap the FCSP out for a Tesla Universal Wall Connector.
