I’m guessing this was tongue in cheek . Transformers don’t slowly wear out voltage ratio-wise. They will go out with a bang though. Worked for a utility for 35 years. There are many reasons your voltage will vary over time. New loads, feeder/ branch circuit changes, adding/ removing line capacitors, you and neighbor’s loads, etc. Oh and a heat wave and resulting AC load can impact it as well. Can your Emporia monitor graph over time?And I think I found why I'm not even getting 17.6kW anymore. When I installed my FCSP, I was reading around 238.5V on my service. I'm now reading 233.5V. And it drops to 223V when the FCSP is actively charging set to 80A. I think the transformer at the road is getting worn out.
