Breaker pops at anything over 30ampsWondering what happens if you plug in something that uses the full 50 amps into one of these while connected to the truck. I assume the Ford EVSE works fine since it is rated for 30 amps.
The Ford Mobile Charger that comes with the Lightning has a 30amp pigtailProbably not. The Ford mobile power cord draws 32a continuous at 240v and would need a 40a breaker minimum, Ford recommends 50a breaker as it uses a 50a plug.
Better off using something below 30a, many adjustable evse on the market now.
