✅ 10/02/2023 Lightning Build Week Group (MY2023)
blend date 08/10
modules up and tear tag up
now "in production" has a date of 17/10.. does that mean it started production on the 17th?
Yes
Status report for the 10/2 build week, the factory is still working the the 10/8 blend day at this time.
Hopefully @cdherman will see some codes by tonight and the remaining 200+ trucks finished by Friday.
Ford F-150 Lightning ✅ 10/02/2023 Lightning Build Week Group (MY2023) 1697714144706
Ford F-150 Lightning ✅ 10/02/2023 Lightning Build Week Group (MY2023) 1697714071877
Danface
Dan
Central Mass
2023 Lightning XLT
I have a 10/6 blend that’s a dealer order. No change in modules or on status (still “In Production” with no date… last update 9/20). Hoping/expecting movement today based on the lag.
Where can one find the "module status"?
blend date 08/10
I assume that Module Status is shown here somewhere?
Ford F-150 Lightning ✅ 10/02/2023 Lightning Build Week Group (MY2023) 1697717015574
Danface
Dan
Central Mass
2023 Lightning XLT
Modules are found here with a VIN Ford-Service-Info
Got the info... it's in XML format. The BCE Module data is in HEX, the NODEID data is a mix of codes and HEX and there are 2 entries in the ERROR block, "PCM DATA NOT FOUND" and "CCC DATA NOT FOUND",
Are those the reading from an OBDII scanner for my vehicle?
Found this:
https://mhhauto.com/Thread-FORD-IDS-missing-XML-files
Looks like I need and OBDII Scanner???
Join the threads about Forscan, etc. I don't think this data is usable without specific software & hardware tools.
Danface
Dan
Central Mass
2023 Lightning XLT
Will do. I was more intrested in what it meant, see my modifed post and thank you!
ejcom12
Eric
2023 Ford Lightning
I've added my info to the tracker. I was given the 10/2 build date as well, but haven't been able to track any updates since then. Either way, happy I found this site! Great source of information. I can't wait to get the truck in!
We look for the codes as indication that your truck is "alive" during the build process, when we see the tear tag, the crucial stages of build are done, the data is sent to the archive for future reference as needed by our service technicians or shade tree tech's with the appropriate tools.
Danface
Dan
Central Mass
2023 Lightning XLT
Thank you!! so where might one find the "tear tag" info :)
Who I'm watching
Ford F-150 Lightning ✅ 10/02/2023 Lightning Build Week Group (MY2023) 1697731651454
cargsl
I just saw the codes for my truck populated overnight but the tear tag is not there yet. How should I interpret this information?
