Yesblend date 08/10
modules up and tear tag up
now "in production" has a date of 17/10.. does that mean it started production on the 17th?
Yesblend date 08/10
It was updated on10/15 and it went into production on 10/14, currently still showing as "In Production"Got the same email.. Pro with max tow.
Where can one find the "module status"?I have a 10/6 blend that’s a dealer order. No change in modules or on status (still “In Production” with no date… last update 9/20). Hoping/expecting movement today based on the lag.
I assume that Module Status is shown here somewhere?blend date 08/10
Got the info... it's in XML format. The BCE Module data is in HEX, the NODEID data is a mix of codes and HEX and there are 2 entries in the ERROR block, "PCM DATA NOT FOUND" and "CCC DATA NOT FOUND",Modules are found here with a VIN Ford-Service-Info
Join the threads about Forscan, etc. I don't think this data is usable without specific software & hardware tools.Got the info... it's in XML format. The BCE Module data is in HEX, the NODEID data is a mix of codes and HEX and there are 2 entries in the ERROR block, "PCM DATA NOT FOUND" and "CCC DATA NOT FOUND",
Found this:
https://mhhauto.com/Thread-FORD-IDS-missing-XML-files
Looks like I need and OBDII Scanner???
Will do. I was more intrested in what it meant, see my modifed post and thank you!Join the threads about Forscan, etc. I don't think this data is usable without specific software & hardware tools.
We look for the codes as indication that your truck is "alive" during the build process, when we see the tear tag, the crucial stages of build are done, the data is sent to the archive for future reference as needed by our service technicians or shade tree tech's with the appropriate tools.Will do. I was more intrested in what it meant, see my modifed post and thank you!
Thank you!! so where might one find the "tear tag" infoWe look for the codes as indication that your truck is "alive" during the build process, when we see the tear tag, the crucial stages of build are done, the data is sent to the archive for future reference as needed by our service technicians or shade tree tech's with the appropriate tools.
Modules are found here with a VIN Ford-Service-InfoThank you!! so where might one find the "tear tag" info![]()
No wonder I didn't see it, it was right in front of me! Thanks
