Dashboard - A Pillar Creaking
Formerly
NY
Ford Lightning 2022
Construction Estimation
All that matters is your sanity and silence 🍻. Glad you got it solved!
bydabeach
NJ
Lighting Lariat ER; Volvo S60 Recharge
I had stubbornly and stupidly thought it was coming from the dashboard/A Pillar Interface. I should have listened to you two. I had not driven the vehicle for the last 10 days of the year, and it was getting really annoying this past week.
I used my plastic putty knife, popped open that panel on the passenger side of the dash that includes an HVAC vent to the passenger side front window. My clips were all plastic. I took a Q Tip and some Vaseline petrolatum jelly, swabbed the clips on the part and the receptacles for the clips, and the creaking noise is gone.
Now the truck is too quiet. :cool:
Oh lawdy, the creak is back with a vengeance. Worse than before. I give up. I have a service appointment Monday for the three "recall" issues, cracked tail light etc, and I will let them figure it out.
VTHokies
Jason
‘23 F150 Lightning Lariat ER (Sept ‘23 build)
Had this issue on the passenger side, dealer took care of it.
Monkey
Somewhere in the mountains
My truck just developed this creak/rattle in the passenger side A pillar location. I'll check that plastic piece. Otherwise will have the dealership look at it when I take it in for the next recall appointment in a week or two... So this seems to be a common issue.
bydabeach
NJ
Dealer took care of mine on Tuesday. It was quiet for a day. Then a little noisier, and now back to the old loud creak. They ordered me a new plastic triangle piece on the side of the dashboard. In the meantime, I just wrapped the clips in teflon tape and the front of the piece that dovetails against the metal bolts. Will see later if that stops the creaking. Probably due to friction between two hard plastic surfaces.
Monkey
Yeah, I popped mine off of there and tweaked the clips a bit to see if I could get a tighter fit. But nope. It’s definitely rubbing against the dash plastic. I might try some teflon dry lube, but don’t want to just add crap to the problem.
bydabeach
NJ
Teflon tape worked for 10 minutes, LOL, and back to the creak. Even my better half, who was not previously bothered by the creak, said that it was annoying.
3rdgenfan
Geoff
Delaware
Absolutely cannot stand creaking. Haven't heard any yet from mine except for where my left knee occasionally rests on the door panel trim piece.
I did notice when doing my speaker installs that the tweeters in the A-Pillar seemed odd. One side had foam surround and the other didn't.
bydabeach
NJ
Ha, ha on foam surround. Not to derail my own thread, but I had a Ford Maverick Lariat Pickup that I could not unload quickly enough. Road noise was horrific, and they put the bluetooth microphone in the driver side A-pillar, and people complained that it sounded like I was speaking from a wind tunnel when using the blue tooth for phone. I had to stuff several bullet microphone foam pieces behind the microphone to quiet it down.
bydabeach
NJ
Went at it with a second layer of teflon tape on the clips, and then put soft velcro around edges of triangular part. Creak is back and as loud as ever. So I took the triangular part completely off and drove around, and the creak is still happening. Will call the dealer.
Not wanting to give up, I found the post below on the ICE F150 forums and the YouTube Video.
I tightened the 7mm lower bolt behind the triangular piece of plastic adjacent to the side view mirror, and it seems to have done the trick. Will see if it holds. Also wrapped all the clips in plumber teflon tape.
https://www.f150gen14.com/forum/thr...eaking-rattling-updated-w-fix.2062/post-31593
bydabeach
NJ
This was another fail, and the creaking came back.
I looked closely at everything near the A-pillar and windshield interface, inside and outside. I pushed on the front fender where it meets the A pillar. It produced the creaking noise. Had the wife sit in the car as I pushed and released the fender at the A pillar, and she confirmed that was the noise. So I wedged a folded up piece of Gorilla tape (orange in picture) between the A pillar and the fender. Pushed the fender up against the A pillar, and no creak. Took the truck on a decent drive and no creak. I think I finally cracked the code.
Not going to drive around with that tape wedged as shown in picture.
Have to go to the dealer for the latest 23B70 Battery monitor sensor software update, and will have the dealer look at this.
Ford F-150 Lightning Dashboard - A Pillar Creaking image000000
Josh S
Josh
Topanga CA
2023 F150 Lighting, 2021 Tesla Model Y
I've had this problem since driving off the lot. Dealer "fixed" it last week, but was only quiet for 30 minutes before coming back more annoying than ever. The vent trim is super loose compared to the driver side. I've tried wedging cardboard in all the cracks, but nothing works.
jthiesse13
Phoenix
2023 Lightning
Good morning! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this creaking noise concern? Thank you!
I have the same "creaking" noise in my 23' Lariat ER. I've taken it to the dealer and they say there's nothing they can do.
bydabeach
NJ
See my post immediately above. This was driving me absolutely nuts. In a previous life, I was an engineer in a factory, and I am a hound dog when it comes to troubleshooting. Try pressing back and forth against the front fender just below the junction at he A-pillar on the passenger side. You can see where I have an orange wad of Gorilla tape wedged there.
Funny thing, the tape slipped out a bit, and the noise came back. I gently pulled the fender back and shoved the tape back down in the gap (without any tools), and the noise disappeared again. Hopefully, this is it for you. I spent a lot of time on the vent trim with absolutely no luck.
Please post to see if this is it. Sometimes the dealer service is quite worthless in these situations.
jthiesse13
Phoenix
2023 Lightning
Thanks, I will try this and repost with the result.
