Wiring and light mounting on front bumper
Runaway Tractor
Yes
I'm planning to put two Morimoto 2banger SAE wide amber fog lights on the front bumper down by the air intake. Has anyone opened up various frunk and bumper plastic trim to get wiring and bolts in there? I have not tried to take the frunk tub apart yet to look. Trying to gather some intel on what I'm getting myself with the disassembly requirements. Ideally as little disassembly as possible.
Before some brings it up, yes I am aware that the lights will partially obstruct a small amount of the air flow. I am confident the conditions I drive in will be fine with no negative impacts. If it does, I will remove them. Not oblivious :)
Ford F-150 Lightning Wiring and light mounting on front bumper 1000013499
Sneakypetie78
Pete
Marina del Rey, CA
2013 F150 limited
General Contractor
There are a few videos on removing the frunk beeper, which to do so, requires removing the frunk tub. not crazy hard, but easier with 2 people or 1 ratchet strap.
Start there. Either in here, or on reddit: f-150Lightning forum.
Runaway Tractor
Runaway Tractor
Yes
jmb01
Oklahoma
2022 Iced Blue Lariat ER
I'm looking for a way to get some fog lights up front also.
mefly2
j
W Montana
23 Lariat ER / KO2s max tow ; 22 F350, 23 C8 Vette
Retired CSc/Math teacher. LEO
gmarcucio
Glenn
Upstate New York
23 Lightning, 23 Corvette, 23 Renegade, 22 Mini EV
Retired High School Auto Tech Teacher
I'm in the process of wiring these DRL's/fogs that I just installed above the recovery hooks. I wanted to stay away from mounting them in the area of airflow. I know that with small lights in the airflow area most likely will not create any problems but if the truck goes into the dealership with an overheating problem and the lights are mounted there good reason for them to say that's the cause and bye bye warranty. Just my opinion.
Ford F-150 Lightning Wiring and light mounting on front bumper IMG_7187
gmarcucio
Glenn
Upstate New York
Nice. Can you show a close up of the mounting method down there? That's very clean looking!
Here is a pic of my install from underneath and some pics of what the lights look like and wiring. I am not wiring the turn signals. I just drilled two small holes in the plastic above the recovery hook and secured the bracket with two sheet metal screws.
Ford F-150 Lightning Wiring and light mounting on front bumper IMG_7206
Ford F-150 Lightning Wiring and light mounting on front bumper 61x8Gb1hf-L._AC_SX679_
Ford F-150 Lightning Wiring and light mounting on front bumper 71VVbKzx0PL._AC_SX679_
Ford F-150 Lightning Wiring and light mounting on front bumper 613kvwGjrqL._AC_SX679_
BennyTheBeaver
Do you have a link for these?
gmarcucio
Glenn
Upstate New York
I haven't tried them in fog yet.
