So, are updates paused still? Feb 2024
Seems like late MY23 trucks included 3 & 4 series updates as-built.
STXLariat
2014 Tundra
I've seen 3 updates in the last 2 weeks. But that was 4.1, 4.2 and today was 23-PU0724-DOM-RS (updated the digital owners manual, I couldn't live without that one). Definitely catching up quickly.
Same for me
1Jetpilot
Jerry
Port Clinton, OH
2023 F150 Lightning Lariat ER
Retired Pilot
I have a late MY23 Lariat ER and I just got 4.2.1 and 4.2.2 about two days apart from each other. Fingers crossed that this is just the beginning!
Did Ford tell you not to worry like they did me? I have a 23 ER Lariat and have not received an update since July 23
subseavet
Herndon, VA
2023 Ford F150 Lightning Lariat Extended Range
R&D Engineer
They did. Incidentally, I got 6.1 on Friday!
subseavet
Herndon, VA
R&D Engineer
Not 100% sure how much it matters, but I did replace the stock AGM 12V battery with the Ohmmu battery about 3 weeks ago, which is around the time the updates started to roll in. I do have the recall software update for the battery control module as well.
detansinn
United States
Since getting the 12V battery monitor service bulletin addressed, I’ve received two updates in the past two weeks or so. I am now at 6.2.
If you’ve been putting off taking it in for that bulletin, do it.
itdwebman
Northeast
I am only 120 days ish on not receiving a successful update. Ford did try and send 4.2.1.1 - but had server/payload issues. I was told it was my last update attempt - even though it was the only update attempt and the Truck correctly rejected it. No reattempts by Ford yet.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
Currently stuck at 6.8 and even FDRS does not have any versions higher than 6.8
Where is the version 7 update?
Want it badly for the BC1.4
My last numbered update was 6.8, then the unnumbered "Improved Diagnostics"
02Reaper
GA
2022 Lightning XLT ER
22 XLT Er here. Got 6.8 in January and got 23-PU113-UNX-DC a couple of days ago.
