PTS/FDRS VIN Check Thread
Revenge
Ryan
2023 Lightning Lariat SR, 2011 Flex
1FTVW1EL5PWG18354 if you would be so kind.
You've gotten 5 updates over the past 4-5 weeks, latest one being 6.1.0. Looking good; hopefully you get more sooner than later.
Schroederhc1
Cordell
Wenatchee WA
2023 Lightning XLT ER, 1990 911 Targa
Self Employed
1FTVW1EV8PWG46408
Thank you
Jasper7821
Ken
Tucson
Lightning Lariat
Aircraft researcher
You ran my VIN a few days ago and said my truck was built last Nov and no updates have been done and I probably won't be able to use the Superchargers.
Would you be able to run it again, I jsut bought the truck and have to drive to Colorado to pick it up Friday and drive 800 miles home and would be great to use Tesla's network since I've been using it for many years before I just sold my Tesla.
The salesperson drove to another dealer where my truck was at and drove it back and said everything was done. I was albe to get FordPass to work and it seems be working fine.
I have an adapter coming today and just wanting to make sure I can use it.
Thank you so much.
1FTVW1EV5PWG61657
lancersrock
Kody
USA - IA
2021 Honda Pilot, 2011 Mustang GT, 2013 fusion se
Field Engineer
Thank you so much.
1FTVW1EV5PWG61657
Just throwing this out there but make sure you plan accordingly in regards to supercharging in the Midwest is mostly V2 chargers and will not work with non tesla vehicles. EA charge speeds are normally good along the I-80 corridor.
lancersrock
Kody
USA - IA
Field Engineer
Other than the super charger update i havent got one since June I think. Ford dealer says everything is fine and nothing is missing but I know that's not true based on missing charge %.
1FT6W1EVXPWG01233
Jasper7821
Ken
Tucson
Lightning Lariat
Aircraft researcher
Yes I’ve planned it out and there’s a few Tesla stops that are 250kw and the other network is only 150kw
@Jasper7821 You do not need the Supercharger OTA in order to charge there, but you will have to use the Tesla App to start the charge (bonus - you can sub and get a discount). The OTA is for using plug and charge with the BlueOval network (no discount).
tbross319
Tyler
Raleigh, NC
2023 F150-Lightning
1FTVW1EV8PWG61037. Built December. Delivered three weeks ago. Stuck in the 4.X trap. Appreciate it!
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
Would appreciate this and screenshot if don’t mind.
I’ve so far seen two updates come in since picked up on 03/20/2024. TIA
1FT6W1EV0PWG49596
itdwebman
Northeast
@rugedraw could you check my VIN 1FTVW1EV9PWG26376 when you have a chance?
I am at 4.2.1.1 - SYNC REV640. Want to be sure the Truck is communicating with Ford Services. Ford OTA team suggested I remove and add back my Truck on the Ford Pass APP?
1FTVW1EV8PWG46408
Thank you
Last OTA was the Tesla update two weeks ago and you got 6.4.0 a few days before that. You've gotten 6 updates in 6 weeks, so it seems like your truck is actively on the roll-out schedule. You should be getting more sooner than later.
Thank you so much.
1FTVW1EV5PWG61657
Nothing has been sent to your truck and nothing has been updated by any dealer. In the thread I mentioned you may not be able to use the Tesla chargers, it was mentioned that is not correct. I don't own an EV and am not well versed on what you can or can't do as far as being able to use different chargers. That may be a question better suited for other EV owners to answer for you.
1FT6W1EVXPWG01233
You've definitely gotten more updates than that since June. A lot more. Last power-up update was 6.4.0 and then a few PU updates since then. The update you are looking is an IPC update and is one of the next ones you are due. There is no way to know when the next one will be sent to you, but you aren't far away from the update you want in terms of the sequence in which they are sent.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712156927181-51
I would not say you're stuck. You've gotten two updates in a little over a week including 4.2.1.2 yesterday. Hopefully you continue to get more soon, but it seems like your truck is part of an active OTA push.
1FT6W1EV0PWG49596
Your OTA dashboard looks identical to the truck above. Two updates in a week last one being 4.2.1.2.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1712157267742-4
Your truck is a week ahead of the two above. You got 4.2.1.1 on 3/1 and 4.2.1.2 on 3/11. Hopefully the trend continues and you will see more soon.
itdwebman
Northeast
Thank you
Crullbri
2023 Ford Lightning Lariat
Semi Retired, Part time Handyman
I guess i am not sure what all this stuff means. I am more interested in if i can do Blue Cruise on my truck. I do not see anything to subscribe to. here is my Vin 1FTVW1EL1PWG01065. Thanks, Brian
Jasper7821
Ken
Tucson
Lightning Lariat
Aircraft researcher
thank you very much, I’ll see if the service dept can do something about it.
