Revenge
- First Name
- Ryan
- Nov 9, 2021
- California
- 2023 Lightning Lariat SR, 2011 Flex
1FTVW1EL5PWG18354 if you would be so kind.
Just throwing this out there but make sure you plan accordingly in regards to supercharging in the Midwest is mostly V2 chargers and will not work with non tesla vehicles. EA charge speeds are normally good along the I-80 corridor.You ran my VIN a few days ago and said my truck was built last Nov and no updates have been done and I probably won't be able to use the Superchargers.
Would you be able to run it again, I jsut bought the truck and have to drive to Colorado to pick it up Friday and drive 800 miles home and would be great to use Tesla's network since I've been using it for many years before I just sold my Tesla.
The salesperson drove to another dealer where my truck was at and drove it back and said everything was done. I was albe to get FordPass to work and it seems be working fine.
I have an adapter coming today and just wanting to make sure I can use it.
Thank you so much.
1FTVW1EV5PWG61657
Yes I’ve planned it out and there’s a few Tesla stops that are 250kw and the other network is only 150kwJust throwing this out there but make sure you plan accordingly in regards to supercharging in the Midwest is mostly V2 chargers and will not work with non tesla vehicles. EA charge speeds are normally good along the I-80 corridor.
Last OTA was the Tesla update two weeks ago and you got 6.4.0 a few days before that. You've gotten 6 updates in 6 weeks, so it seems like your truck is actively on the roll-out schedule. You should be getting more sooner than later.1FTVW1EV8PWG46408
Thank you
Nothing has been sent to your truck and nothing has been updated by any dealer. In the thread I mentioned you may not be able to use the Tesla chargers, it was mentioned that is not correct. I don't own an EV and am not well versed on what you can or can't do as far as being able to use different chargers. That may be a question better suited for other EV owners to answer for you.You ran my VIN a few days ago and said my truck was built last Nov and no updates have been done and I probably won't be able to use the Superchargers.
Thank you so much.
1FTVW1EV5PWG61657
You've definitely gotten more updates than that since June. A lot more. Last power-up update was 6.4.0 and then a few PU updates since then. The update you are looking is an IPC update and is one of the next ones you are due. There is no way to know when the next one will be sent to you, but you aren't far away from the update you want in terms of the sequence in which they are sent.Other than the super charger update i havent got one since June I think. Ford dealer says everything is fine and nothing is missing but I know that's not true based on missing charge %.
1FT6W1EVXPWG01233
I would not say you're stuck. You've gotten two updates in a little over a week including 4.2.1.2 yesterday. Hopefully you continue to get more soon, but it seems like your truck is part of an active OTA push.1FTVW1EV8PWG61037. Built December. Delivered three weeks ago. Stuck in the 4.X trap. Appreciate it!
Your OTA dashboard looks identical to the truck above. Two updates in a week last one being 4.2.1.2.Would appreciate this and screenshot if don’t mind.
I’ve so far seen two updates come in since picked up on 03/20/2024. TIA
1FT6W1EV0PWG49596
Your truck is a week ahead of the two above. You got 4.2.1.1 on 3/1 and 4.2.1.2 on 3/11. Hopefully the trend continues and you will see more soon.@rugedraw could you check my VIN 1FTVW1EV9PWG26376 when you have a chance?
I am at 4.2.1.1 - SYNC REV640. Want to be sure the Truck is communicating with Ford Services. Ford OTA team suggested I remove and add back my Truck on the Ford Pass APP?
Thank youLast OTA was the Tesla update two weeks ago and you got 6.4.0 a few days before that. You've gotten 6 updates in 6 weeks, so it seems like your truck is actively on the roll-out schedule. You should be getting more sooner than later.
