Any product to convert front tow hook to hitch receiver?
bigskydu
Big Sky, MT
2021 F150 Platinum 6.5' Powerboost
I'd like to mount a winch on a hitch plate (something like this: https://www.amazon.com/ECOTRIC-Moun...rds=Hitch+Mounted+Winch&qid=1616518758&sr=8-2) so I can use the winch in the rear or occasionally in the front of the truck.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 71UoaincbjL._AC_SL1500_
Has anyone seen a swap for the front tow hook to make it a hitch receiver? Googling shows me a guy who made one years ago but that seems like a dead end now.
Looked like this:
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 108d1443545130-tow-hook-front-end-hitch-hook-hitch
Any other thoughts on the goodness or badness of this idea are welcome. :)
Pedaldude
Arizona
Which engine does your truck have? There’s a good spot for one of these where the intercooler lives on the turbo engines, so if you have a V8, or the 3.3 V6, I imagine that it won’t be long before the aftermarket figures something out.
bigskydu
Big Sky, MT
Powerboost 3.5
jeffcrum
Slidell, LA
2021 F-150 XLT 302A Powerboost 7.2kw Inverter
Computer programmer
I am looking to do the same thing. I can only find two old options from years ago.
All I see now is the tow hook to shackle conversion. That one doesn't make sense to me. Soft shackle to connect tow hook and recovery line ... All good.
A tow hook to receiver conversion gives so many more options.
bigskydu
Big Sky, MT
Agree! I've found nothing aside from those old posts. There is a front tow-hitch receiver that bolts on to the bottom of the chassis but it requires removing or cutting the air dam which I'm not interested in doing.
jeffcrum
Slidell, LA
Computer programmer
GarageMahal
JT
Data Wrangler
I am also looking to use a receiver mounted winch and was planning to get a full front hitch (see link below). I see the appeal of replacing the tow hooks but am concerned about the overall strength.
https://www.curtmfg.com/part/31083
My only question at this point is will it fit on a 2022 Lightning...
Edit: I agree that cutting the lower air dam isn't ideal but it should be a cheap enough part to pick up at a salvage yard so I don't have to mess with my original.
jeffcrum
Slidell, LA
Computer programmer
Just a tease ... more to come.
@bigskydu
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211010_185159
jeffcrum
Slidell, LA
Computer programmer
Okay. Here it is. A huge thanks to my neighbor, @NEWT32, for all of the help. We had a blast doing this. He was just as excited as I was ?
First, a couple things.
1. The tow rings are easy to remove. Two bolts each. But, the bolts are attached to each other inside the frame, but loose and move around. If you take them both out at once, they move on you. You can get them back in place. Grab a flashlight, magnet, and screwdriver. Have patience!
2. The rear bolt is between two pieces of plastic and annoying. The front plastic is on with clips. We left it alone. The rear one comes off with three screws on each end. Take that off. But, maybe mark it with the receivers first. I cut the passenger side on the truck. Measured it after to cut the drivers side. It didn't line up. So. It went back on with a little force and bent plastic.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211010_194416
Remove the tow hooks and rubber piece around them. Only one bolt is required to be removed. It slides over the other loosened bolt.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211010_205749
I used the recievers I linked above. That length actually butts up against a bracket further back.
Half inch holes on one side for the bolts and inch holes on the opposite side for the socket.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211010_193122
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211010_193130
Center of half inch hole is 4 inches from the back. Center of front hole is 3 inches from center of back hole.
We drilled the half inch hole on a drill press and went all the way through the back side. Then a one inch bit to enlarge the top side hole.
It takes some maneuvering to bolt it on. Once you get one bolt started, crank it in a bit. You can then spin it back and forth to get the second nut (remember, they are connected) inside the frame lined up.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211010_194744
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211011_095334
We had to shave a bit off the top of the reciever on the winch mount to clear the bolts to get it in far enough for the pin.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211010_205818
Due to the bumper trim, the pin is difficult to get in and out. But, it is doable. The left pin will not go in, but the right one will.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211011_094536
We have a possible plan to turn my locking pins and shorten them. I'd love to keep my Factor55 Hitchlinks in there. I'll report back how that goes.
The Factor55s fit in without modification.
Let me know if there are any questions. I am sure I left out something important :ROFLMAO:
jeffcrum
Slidell, LA
Computer programmer
I have these locking hitch pins
https://www.amazon.com/dp/B07Y7YSR11
We shortened two of them and inch and recut them for the lock. We also cut the butt end down by about half.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211024_150047
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211024_150104
The pins go in easily now. But, the lock does not. We'll be taking a rototool to the lower trim shortly.
jeffcrum
Slidell, LA
Computer programmer
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211024_165351
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211024_165354
Okay, just bought these. We think it will fix my issue without modifying the truck. Lock orientation.
https://www.amazon.com/dp/B085QFS6DK
I'll let you know. And, just painted the recievers.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211024_171350
jeffcrum
Slidell, LA
Computer programmer
Good news and bad news.
The bad news is that the cut is different on these for the locks.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211030_092623
The good news is that we get to play with the lathe some more :ROFLMAO:
FORDHOSTAGE
Banned
Banned
Banned
Bob
Saint Lunaire-Griquet, NL A0K 2X0
F150GEN14
Hostage
I've been in way too many situations where I needed a winch on the back, not the front.
The tow receiver mounted winch gives you the versatility to pull from either end.
Seems like a "no brainer"!
Thanks for the posts!!
FORD is AWESOME!
jeffcrum
Slidell, LA
Computer programmer
And, we have it!
New pins cut down an inch like the first set. Then, the lock is recut to match the new ones.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211107_154752
The pins fit inside out.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211107_154909
With the lock attaching from the outside and the key pointing up/down/front/back.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211107_154917
And, the completed project from the front.
Ford F-150 Lightning Any product to convert front tow hook to hitch receiver? 20211107_154858
This was fun to do. @NEWT32 and I had fun doing it and sharing here.
I feel the front of my truck is more functional!
Twg1
Tim
SamandLily1
2006 F150 Screw, 2019 Camaro ZLE
