Tailgate fell off, lol
dothedew
Colorado
My tailgate fell off while I was loading a mattress this afternoon, lol. It looks like parts are missing on the right side mount versus the left. Can anyone share pictures from their truck of the same?
Ford F-150 Lightning Tailgate fell off, lol IMG_4460
Ford F-150 Lightning Tailgate fell off, lol IMG_4459
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
Looks like a standard truck bed. Is this your first truck? One side is usually slotted so you can take off the tailgate.
dothedew
Colorado
You were so focused on making the condescending post about being a ā€œfirst truckā€ that you missed the point of my thread that I am trying to determine what parts are missing. Iā€™m not sure any certain number of years of truck ā€œownershipā€ would give someone enough experience to draw the tailgate assembly and parts from scratch without any reference, as noted by your complete failure to miss the gaping hole in my picture where clearly something belongs but I am mot sure what.
dothedew
Colorado
Who took the set screw out?
Thank you so much, really appreciate your help. Looks like I need to visit the parts counter.
My guess is the bedliner installers forgot to put the set screw or didnā€™t torque it down properly and it worked its way out.
Blochead21
PA
Black 22 XLT 311pkg
Pretty sure I donā€™t have a screw hole holding in the right side of my tailgate. I didnā€™t need to remove any screw when removing the tailgate to add in the damper.
bydabeach
NJ
Lighting Lariat ER; Volvo S60 Recharge
Just checked. I have the same screw (bolt) that @Tony Burgh has. Looks like you had a missing screw or a screw loose (no pun intended-being factual!). :muscle:
Clearly the guys that sprayed the liner removed it and didn't put it back. That said, it has to be lifted out and how did that happen?
dothedew
Colorado
I had the mattress halfway into the bed with the tailgate closed and the tailgate open button got pressed accidentally so it started opening while there was lateral pressure on the tailgate so I am assuming when the lifter got to the right angle it popped out.
Hopefully no damage. If it did get damaged, I be calling them...
Minh
Minh
NJ
Interesting, didnā€™t have the screw on the pro and lariat. Anyone know the bolt size?
