Panoramic sunroof gasket failing - 2023 Lariat ER
Rocket808
Rocket
Los Angeles
All-
TLDR- rear sunroof gasket failing. took into dealer and “they will get back to me”
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_3305
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_3307
so I try to wash my truck by hand every couple of weeks, and noticed this during the weekend wash. Rear panoramic sunroof glass gasket. It has failed on the passenger side, and beginning to fail on the aft drivers side as well.
have any of you had this failure?
1 year (almost to the day, approx 15k miles)
any suggestions to cover this until the dealership returns my request for warranty repair? My expectations is that the warranty will replace it - any thoughts?
ctuan13
Chuck
Pittsburgh, PA
All-
That is definitely not normal. Hopefully the dealership gives you an answer. Just out of curiosity, how are you washing your truck and what are you using to do so?
Dan C
Dan
2023 lightning lariat, 2022 Chevy bolt
All-
Looks like rodent damage, better find out before they eat something more expensive.
kstype
Kurt
Pennsylvania
Senior Systems Engineer
Ugh - sorry to see this.
My Lariat ER has 41,000 miles on it now and the gaskets are perfectly fine. I live in SE PA and the truck is parked in garage. I would agree with earlier comments - it does seem like damage caused by a bird or rodent tearing at it.
rlbussard
Ron
Army MSG Retired
All-
Definitely looks like something got a hold of the gasket. I have owned a bunch of F150 ICE and 2 Lightnings with sunroofs and I have never seem that happen before.
Adventureboy
Ford has been making the moon roof for quite a while so failure (at least on the fixed seal) should be rare. I agree it looks more like rodent/bird damage than product failure. Pieces are missing and the remaining seal seems intact. Something is chewing on that. Set up a motion sensor camera on it for some time.
Rocket808
Rocket
Los Angeles
Step ladder, hand washed with microfiber mitts for the top. No step ladder for the rest!
Electric_hillbilly
Enrique
Grass Valley, CA
2023 Lighting
Military
Mine was replaced yesterday. 13k miles I don't believe I had damage like that but had bad seal and was leaking inside the cabin after a few hours of heavy rain.
No garage though mine is a 100% outdoor truck
DaGriff
‘23 Lariat ER Carbonized Grey
Plumber
Interesting to see this happen like that. I also have a Lariat with the roof and it is 100% outside, no garage time. Maybe its time to get a shelter?
Rocket808
Rocket
Los Angeles
I park mine outside 100% outside too. Los Angeles concrete jungle so not a lot of animals climbing on the truck.
one side of my gasket (that is degraded) is very puffy and soft - almost spongy. The other side (drivers side) is much stiffer feeling. The stiffer side has a spot that is separating from the glass. New photo is the stiffer side and you can see it separating.
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_3309
For those who had it fixed, what did it cost you?
I’ve seen costs of $2000 or some such for different automobiles. If it is just a silicone gasket then I don’t know why I wouldn’t just use a silicone tube.
but from what many of you are saying - I don’t know why something that animals favor to grub on would be used.
thanks all and keep ideas coming!
Electric_hillbilly
Enrique
Grass Valley, CA
2023 Lighting
Military
Mine was covered by warranty $0 out if pocket. Did have to go twice, one for diagnostic and another time when the part arrived. The whole thing took a few weeks but both the diagnosis and installation was about 4 hrs. Dealer is close to work so no significant impact on daily schedule.
Did yours leaked also during the last rains?
Rocket808
Rocket
Los Angeles
Not that I noticed. I didn’t even notice the gasket issue until this weekend
we did get a lot of recent storms, so maybe I just got lucky
HHI-Lightning
Rick
South Carolina
F-150 Lightning Lariat ER
Thanks for starting this post.
I’ve got a brand new (2 weeks) Lariat, which has been garaged since being purchased. After seeing this post, I checked my moonroof gasket and see extensive deterioration (see pics).
I don’t know how long the truck sat at the dealer before I bought it, but this seems to be a lot more than what an animal could accomplish. Maybe there is a material defect issue???
Off to the dealer asap
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_1799
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_1798
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_1797
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_1795
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_1794
Ford F-150 Lightning Panoramic sunroof gasket failing - 2023 Lariat ER IMG_1796
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
ouch! OP's post looks more like a rodent issue. However, your truck looks like its completely dry rotted out.
