Using ABRP, is OBD worth the investment?
thicketmatt
Matt
Atlanta
‘23 F150 Lightning Lariat ER max tow
Ocean shipping, retired
I use ABRP for my planning, but I do not have live data via an OBD dongle. Do you feel it’s worth the investment? If so, which make/model do you suggest (and any supporting apps) for an apple iOS user. Thanks,
I have put tens of thousands of miles on my two EVs. I use ABRP extensively, and simply use the free version. No reason to pay or get live data IMO.
swajames
CA
Technology and software development
If you're using iOS the Apple Maps EV integration is a big upgrade over the standard nav as it factors in your real time SoC etc. I do have a Bluetooth LE OBDII dongle and it works well with ABRP. I got by just fine with the non-live data version too, but with live data it's better.
This is the OBD link I use - https://www.amazon.com/gp/product/B08NFLL3NT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
With that reader and an app like Car Scanner (which has a profile for the Lightning) you can see an absolutely immense amount of data for your Lightning.
jlcreasy
2023 Lightning Lariat
I use the same ABRP and adapter. I've found it very useful and for me much more range accurate than the update Maps EV.
Golieguy64
Jason
Wisconsin
2023 F150 Lightning Lariat ER
It is probably just user error, but for the life of me, I can only select F150 BEV profile, and it only reads out useless F150 ICE data on the diags, etc. Is that the right model to select, or is there an entire different profile I should be using?
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
I use the Mustang Mach E/F-150 Lightning profile.
Ford F-150 Lightning Using ABRP, is OBD worth the investment? IMG_0659
swajames
CA
carys98 answered you too, that's the profile I use albeit my connection profile is slightly different in that it also references the E-Transit. That may just be an iOS vs Android thing. Regardless, yes there is indeed an absolute TON of EV specific data avaialble to you with the right profile.
Ford F-150 Lightning Using ABRP, is OBD worth the investment? IMG_2225
carys98
Cary
Raleigh, NC
There must have been an update. I went through the menu again and now I have the E-Transit version. The old one is gone so I wonder if they just renamed it or if there are some new PIDs.
